Head check?
Old May 7, 2015 | 09:29 PM
Royson12's Avatar
Royson12
Head check?
I'm finally workin on puttin my 6.9 together. I am wondering about the heads. Is that something easily tackled? What about the precombustion chambers? Or should I just get out my wallet?
Old May 9, 2015 | 09:28 AM
PlumCrazy7's Avatar
PlumCrazy7
Since no one with experience has replied I'll just say go with your gut. If you worked with heads before and feel comfortable go for it. Lapping valves is simple, a good torque wrench for the springs, the only thing I can think of that may require finesse is installing valve stem seals. If you have or can find the tools go for it.
Edit: There should be no reason to touch the pre cup or chamber, just see if there are substantial cracks in the pre-cup. AND get the head magnafluxed by a good reputable shop.
Old May 9, 2015 | 02:49 PM
Royson12's Avatar
Royson12
10-4. Will do. I have actually rebuilt gasser heads before. Just never diesel. So, I should be allright. I do have a good ford factory service manual.
Old May 9, 2015 | 07:04 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
^^^ x2 on the magnafluxing it is cheap and quick, must shops will do it for free. These heads are prone to cracking.
Old May 10, 2015 | 09:50 AM
Chevy_Eater's Avatar
Chevy_Eater
There will be cracking on the precups, but as long as they don't reach the fire ring they are okay.
I don't think they are available anymore.
Old May 10, 2015 | 10:03 AM
Royson12's Avatar
Royson12
Can you explain what the fire ring is? Or is it pretty evident when you pull them?
Old May 10, 2015 | 10:13 AM
Chevy_Eater
It's the metal ring around the cylinder on the head gasket. If the cracks on the precups pass through were this ring sits on the head it can create a leak point.
It will be obvious when you pull the head, the ring leaves its mark on the head and block.
Old May 11, 2015 | 08:26 AM
Royson12's Avatar
Royson12
I see what you are talking about. What are the chances of removing them without damage, for cleaning of the block? I've read, they are expensive and hard to find.
cookingguy
Apr 17, 2019 12:24 PM
vlietracer64
Nov 25, 2012 01:52 PM
leeward
Jan 22, 2007 07:25 AM
rickkk
Jun 2, 2004 07:04 AM
alh66f100
Apr 4, 2004 06:40 AM
