New head gaskets??
Old Apr 15, 2019 | 08:34 PM
cookingguy's Avatar
cookingguy
New head gaskets??
So when doing new head gaskets on a 6.0 do I have to have the heads completely gone over or can I just get the head surfaced and do my new gaskets and head studs. Or is it worth it to drop 1200 to have to heads totally gone over.
Old Apr 15, 2019 | 09:01 PM
ford390gashog's Avatar
ford390gashog
Before you spend any coin on machine work you need to have the heads checked for cracks. The heads are notorious for cracking and new heads are the answer.
Old Apr 15, 2019 | 09:20 PM
cookingguy's Avatar
cookingguy
So let's say my heads are not cracked and the are flat and not warped. Do I need to have the totally re done.
Old Apr 15, 2019 | 10:17 PM
TooManyToys.'s Avatar
TooManyToys.
That depends on your intentions for the truck.
If you don't have good experience rebuilding motors or know the issues you are better off having a reputable machinist go over them.
If you are damn comfortable with the work, both as a mechanic and machinist, you first have to clean the decks, check for flatness - two approaches, Ford's latest TSB or the original cross surface flatness. Then pull the valves and inspect the valves for pitting and margins, seat surfaces, and the stem to guide clearance for wear. Once the seats are very clean you can do an inspection for cracks and pitting, although Magneflxing is the better method of checking. Not foolproof, as with all techniques.
So now you've done all the cleanup, all the measuring, all the inspection, and if anything is amiss, now you can take it all to the machinist to repeat all of that himself before fixing what needs to be done.
I'm getting away with working my heads at home, but my heads meet the specs. Some exhaust valves were too pitted at 75k miles, so they're getting all new valves since I don't have a valve grinder in the garage. Having a shop do the valves would be cheaper, but that piecemeal work the only a good buddy would do. And in that case, he'd be doing the heads anyway.
Old Apr 17, 2019 | 07:31 AM
cookingguy's Avatar
cookingguy
I'm ok with doing the inspection my self. And checking for flatness. Hopefully all the valves will be good to go. However I may need to find a shop to magflux it as I don't own a giant magnet
Old Apr 17, 2019 | 10:01 AM
TooManyToys.
You can dye check, which if done correctly works as well. Even Magnaflux will tell you there dye check done properly can be better than the magnetic testing done poorly. When everything is really clean a visual inspection will work as well as the
Old Apr 17, 2019 | 10:44 AM
namnguye's Avatar
namnguye
Jack, for mower engine, people just lap it on the head. So for the 6.0, is it correct that is just not a good option doing that way?
Old Apr 17, 2019 | 12:24 PM
TooManyToys.
It all should be done at a machine shop.
But even with that, there are some who will lap after machining. It's a debatable situation. Some machinists say lapping after machining creates more issues. I've done it with HiPo motors with success, but not using the standard lapping compound in a tube. You can get Clover lapping compound in a corse and fine grade, but even that company has grits down to 2,000 grit range.
At the end of the day, you have to check the seal by pulling a vacuum, and I've had discussions in the past when it's been said none of that truly matters because there are minute changes at the surfaces due to the temperatures and the seats don't stay where they are. So, in essence, they have to wear in place. Of course, lapping is wearing in the surfaces. But that's cold. It's a circular discussion.
A person can try lapping in valves, but you have to vacuum check and you should blue the parts and see how contact really is. That's a lot of work and just easier to get it all done in a shop.
Tex51
Oct 9, 2018 06:06 PM
CountryMonkey07
Jan 20, 2018 08:39 AM
atvguy14
Jan 17, 2017 06:25 PM
vlietracer64
Nov 25, 2012 01:52 PM
AndeyHall
Mar 11, 2012 05:45 AM
