Sponsored by: Real Truck
Ticking noise
Old May 7, 2015 | 08:40 AM
Superdutystiller's Avatar
Superdutystiller
Ticking noise
Can anyone describe the difference in sound between a lifter tick and an exhaust leak? I have a ticking noise, almost sounds more like a puff of air noise, it only makes the noise when I push the accelerator and is coming from the right side. Noise is most noticeable if I put my head under the passenger side front fender. I am guessing I have an exhaust leak somewhere between the heads at cat but just wondering if anyone can explain the difference in sound. I'd think if it were the lifters they would tick at idle, right? The truck sounds great at idle (after doing a tune up) I just want to get rid of this annoying tick when I accelerate. Thanks for any help!
2002 Ford F-250 5.4l
Old May 7, 2015 | 08:50 AM
Superdutystiller
Video of the noise
http://youtu.be/_Lk2yqUvwaE
Old May 7, 2015 | 12:27 PM
Wolfboro's Avatar
Wolfboro
Did you check your exhaust manifold bolts ? any broken bolt ?
Ticking noise could also be related to a "loosened spark plug" ( just prior to blow out ) . Several forum members got this ticking noise and ended up with a blown spark plug ( Timesert was the correct solution).
I recommend that you take the time to check all spark plugs ( Ford Spec. 14 ft-lb).
Good luck
Old May 7, 2015 | 01:51 PM
Superdutystiller
I will check the exhaust manifold bolts. The spark plugs were installed new yesterday so that isn't the issue. Thanks for the help!
kirksey228
Mar 12, 2012 06:34 AM
mossyoak1
Dec 22, 2009 10:48 AM
padec21
Modular V10 (6.8l)
Jul 19, 2009 09:45 PM
900rr
Modular V10 (6.8l)
Jun 10, 2008 03:01 PM
NASCARTruckDude
Modular V8 (4.6L, 5.4L)
Aug 4, 2003 10:30 PM
