Unusual Sound
Old May 5, 2015 | 06:57 PM
Etzcutter's Avatar
Etzcutter
Unusual Sound
6.0L Forum - I need your help.
I've noticed an unusual sound on my truck. Upon driving if I make a turn more than 15 degrees a "rubbing" sound can be heard through the turn, no "knocking" is not present. Once the steering wheel is straight the sound changes to a "whir". If I turn less than 15 degrees a noticeable sound can not be heard. As the RPM's vary, the sound will also vary. If I get out of the truck and listen for this sound in the engine bay I can not hear it. The sound is only distinct within the cab. It sounds like a weak motor trying to move something or a pump running low, my guess in the dark.
I've checked the oil level - good
I've checked the transmission fluid level - good
I've checked the power steering fluid level - good
I've checked the brake fluid - good
I have read that a master cylinder could wear and create a rubbing/unusual sound. What else should I check for? The truck has 238,000 miles.
Thanks in advance.
Old May 5, 2015 | 07:13 PM
Iaff113's Avatar
Iaff113
Any pull when you let your hands off the wheel or while braking?
Old May 5, 2015 | 07:27 PM
dieselbogging's Avatar
dieselbogging
I'd check the hub/bearing assemblies for play or noise. Possibly be the tires rubbing on the mudflaps.
Can you duplicate the sound without moving?
Old May 5, 2015 | 09:41 PM
78fordman's Avatar
78fordman
Unusual Sound
have you flushed the power steering fluid?
Old May 5, 2015 | 10:05 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Have ESOF or manual hubs?
Josh
Old May 6, 2015 | 09:21 AM
Etzcutter's Avatar
Etzcutter
No, took the truck out for a drive last night. Did not notice pulling when releasing the steering wheel or applying the brakes.
Yes, the sound can be duplicated when the truck is not moving.
Old May 6, 2015 | 09:23 AM
Etzcutter's Avatar
Etzcutter
No, I have not recently flushed the power steering fluid. Can you walk me through this thought? Why would the current power steering fluid cause the noise?
The steering does seem a little sloppy, not very smooth.
Old May 6, 2015 | 09:24 AM
Etzcutter's Avatar
Etzcutter
Josh
I have ESOF that doesn't work and have to manually lock the hubs for 4WD.
stemo76
6.7L Power Stroke Diesel
May 18, 2023 03:08 PM
wrxin
Sep 22, 2019 04:50 PM
redman84
27
Dec 16, 2013 11:52 AM
sum_weirdo
Jun 7, 2010 07:56 PM
