Help!!!
Old May 6, 2015 | 09:11 AM
rhino25's Avatar
rhino25
This morning it drove fine, didn't misfire at all. Would the temperature outside do anything? It was cooler outside this morning, than it was yesterday... I found the second fuel filter. I'll try replacing that this evening.
Old May 6, 2015 | 09:44 AM
InfantryCPT's Avatar
InfantryCPT
A crapped up filter will do this let us know how it runs after you change it. Take heed and read the directions to replace
Old May 6, 2015 | 11:30 AM
arctic y block's Avatar
arctic y block
Subscribing. Very interesting.
Old May 6, 2015 | 12:24 PM
roadrash63's Avatar
roadrash63
seafoam
Try seafoam in the intake.
follow the directions on the can or utube...
Carboned valves
Old May 6, 2015 | 12:29 PM
roadrash63's Avatar
roadrash63
mine sounded like popcorn as I was blowing it out down the road...
Old May 6, 2015 | 09:38 PM
rhino25's Avatar
rhino25
Nope. Wasn't the filter. Might be idling a little better but that's about it.
Old May 7, 2015 | 07:35 AM
InfantryCPT
What codes are you getting now? Also are you running a cat? Lastly have you verified your timing, please refer to this thread again to set your timing as per spec
https://www.ford-trucks.com/forums/1...-0-efi-12.html
posts 175-182
Old May 8, 2015 | 09:28 AM
rhino25's Avatar
rhino25
I think it's the egr valve. I unplugged it to make it stay shut, and it hasn't cut out since. I will drive it for a few more days and see if it acts up anymore. I appreciate the help.
Old May 10, 2015 | 01:15 PM
rhino25's Avatar
rhino25
Okay. It's stopped doing the back firing since I cleaned the egr valve and changed the spark plugs and wires. It has started to jerk once while I'm driving, and has died a couple of times while just cruising at a steady 55 mph. Any ideas???
Old May 10, 2015 | 01:21 PM
InfantryCPT
a failing fuel pump maybe the culprit, any codes? Is the fuel pump in the tank on your truck, forgive me, I'm not that awful familiar with the FI trucks
b3dazzl389
15
Oct 17, 2011 07:23 PM
cam4x4
32
Jul 31, 2011 08:56 PM
JRMSVT03
Aug 20, 2010 10:43 PM
msgntsu
Apr 25, 2006 01:56 PM
ecsmith0624
Oct 28, 2003 08:21 AM
