Surge Protection - lets hear what you have...
Are you guys with this hardwired into your rig do you check the power post before hooking/ setting up?
I've been using this and can say there has been a few times that this has shown a bad electric post before even wasting anytime on that site.
Smart RV Surge Protector, 50-amp - Progressive SSP50 - Surge Protectors - Camping World
Your unit is the exact same thing as the hardwired unit we all have been referring to. It checks the power just like yours when first plugging in. I haven't had a chance to use it like you describe yet as I just got it but I've heard a lot of people say the same as you so this season will be interesting. Now to remember to plug in before setting up camp...LOL.
I personally went with the hardwired as it's always setup, can't be stolen, isn't out in the elements, and isn't a giant box hanging off the park power outlet. The hardwired also has a remote display that you can mount inside your RV to keep an eye on any codes, voltage, line frequency, amps drawn, etc. The remote also allows you to bypass with the flip of a switch.
I just pulled the trigger on the Progressive Industries unit.. Spent a few dollars more but they have free shipping - so $320 did it...
Progressive Industries 50 Amp Permanent Electrical Management System with Remote Display - Surge Guards - Power Protection - Electrical
Thanks for all the tips and pictures! Quite helpful.....
That is the same unit we have in ours Randy. Ours has worked well and saved us a few times. I always plug in and check the readout before going through the setup process.
However, nothing is perfect. A lightning strike nearby still blew out our stereo last year. Don't know if anything could have saved it, but nothing more expensive died. Don't even know if the surge came through the wiring from the post.
We camped from 1988 to 2002 in a 28ft Jayco 5th and never had any surge protection. Never lost a thing. Then again, new trailers have a ton more electronics that we need to protect.
I had a 30 amp TRC in the old 5er that worked just fine (and pulled it out when the unit was traded and have it up for sale now). With the good service of that one, bought the 34560 50 amp version. I probably would have purchased the Progressive unit instead if I had done my 'homework' better. Evidently the TRC warranty and customer service have gone into the toilet. I'll need the remote reader and some hook up cable before I can install it though - another hundred plus bucks though it is well worth the cost based on some of the poorly wired CGs we've visited.
Pole breaker OFF (50A)
Converter Breaker OFF (50A)
Plug in the power cord - Pole Breaker ON
Verify that the EMS likes the power (watch the remote display)
Converter breaker ON
Tell the Bride she's got the power (like I have to)
Head for the fridge
Received 6,870 Likes
on
on
Steve, thanks for the quick response. I'm not familiar with the wiring in my trailer so I'm not sure about the transfer switch. I went poking around the Progressive site after I posted and they say to install prior to the transfer switch. Here's what they posted in their FAQ:
Edit: I don't even know where my transfer switch is. I didn't even know what it was until I started reading up on this unit. I have a lot to come up to speed on.
Q: Should a Hardwired EMS be installed before or after the transfer switch?
A: A hardwired EMS should be installed prior to the transfer switch. The reason for this is most RV generators already have built-in voltage and frequency protection. If the EMS is installed after the transfer switch, this leaves the transfer switch vulnerable to power problems.
Last edited by HRTKD; 05-14-2017 at 04:57 PM. Reason: transfer switch? I have a transfer switch?
I do agree the risk is low from the generator as when the module board or voltage regulator fails, in my experience it fails by putting out no power at all.
As an aside the one thing I have noticed is the power in campgrounds has improved so much that problems have become a rarity as in the past they seemed to me to be commonplace.
Steve
Their answer makes no sense as all power generating equipment has built-in frequency and voltage controls. Yes, the transfer switch would be at risk if you install the Progressive after, the switch but if you install it before the transfer switch is still at risk from the generator. Transfer switches are relative cheap in comparison to all of the equipment it feeds. It is more like pick your poison.
Steve
Steve
We now have a Progressive EMS hard wired system wired after the generator with a remote reader inside the trailer.
Denny
shurik74
01-19-2017 01:23 PM
rvpuller
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-18-2016 07:48 AM
BPofMD
08-07-2013 12:20 PM
Sn0wMan
11-14-2004 12:30 AM
