Glow plugs?
Old May 5, 2015 | 06:10 AM
ExPACamper's Avatar
ExPACamper
Glow plugs?
Probably dumb questions, but here goes.
1. What Glow plugs should I use in my 2002 7.3L Excursion Limited?
2. #3 is throwing a CEL on my California model. Should I replace just it or all 8?
I am replacing the UVCH on both sides, so we'll be in there.
I've seen the ZD-11 listed. Is it superseded, a better one, stay OEM, etc?
Thanks!
Old May 5, 2015 | 06:23 AM
dsquared's Avatar
dsquared
OEM BABY!!! Lots of issues with others, such as tips swelling, etc. Info I've gleaned from FTE; put in memory banks just in case....
Old May 5, 2015 | 06:32 AM
JuanHuevos's Avatar
JuanHuevos
Hey John, make sure you re-torque your injectors while you're in there! I just did the 50¢ fix and found 3 slightly loose injectors. 120 in/lbs!
Old May 5, 2015 | 06:40 AM
jhl3's Avatar
jhl3
Agreement x2. OE FORD "only" from FORD or RR or DO. Some aftermarket GP"s do experience having the tip swell after hundreds of cycles of heating, cooling and every detonation when the cylinder fires each time. If you use aftermarket and the tips swell, the next time you replace them you will be pulling the heads.
If you have a bit of time Riffraff and DieselOrings have them for less money.
Replace all eight for less than $100. Too much trouble pulling VC's etc. to do only one.
Old May 5, 2015 | 06:56 AM
ExPACamper's Avatar
ExPACamper
Excellent info!
Excellent, thanks!
120 in-lbs, OEM, all 8. Fast and helpful. PERFECT!!!
I hope I can return the favor some time
Here's my build thread with lots of pics. I have more if anyone needs more. I just finished the fuel bowl rebuild and adding the fuel pressure sending unit, and the 4" MBRP exhaust.
https://www.ford-trucks.com/forums/1...l#post15327623
My tip? Look at the pic of the before and after pics of my fuel bowl and all the gunk in it, then make sure you check yours
(Beware the large pics. Apparently my phone is stuck on the "Godzilla" setting )
Seriously, you guys ROCK!
Old May 5, 2015 | 07:07 AM
jetdoc's Avatar
jetdoc
I was in a pinch and bought Motorcraft GP's at Autozone....
Old May 5, 2015 | 09:14 AM
ExPACamper's Avatar
ExPACamper
Ordered a set of 8 ZD11's from AdvanceAuto. With their specials, came out same or better than the other options- and they will have them for me at 1230 local time
Thanks again for all the fast advice!
Old May 5, 2015 | 12:41 PM
JuanHuevos's Avatar
JuanHuevos
Sounds good man, good luck! Call or text if I can help you out!
Old May 5, 2015 | 01:44 PM
ExPACamper's Avatar
ExPACamper
Thanks, I appreciate it! Still haven't made that custom bracket for the new fuel filter- so haven't done the Hutch mod yet
Old May 5, 2015 | 02:49 PM
Glowplugger's Avatar
Glowplugger
Probably should torque your rocker arms too, 240 in/lbs (20 ft/lbs). Since you're in there. If any of them are loose you'll notice it being a lot quieter afterward. One thing I wish I'd done while in there but didn't, is do my injector o rings seals etc.
Old May 5, 2015 | 03:03 PM
FiznUKa's Avatar
FiznUKa
120 in/lbs on the injectors not the glow plugs. Hopefully someone has the torque for the glow plugs.
Old May 5, 2015 | 03:51 PM
ExPACamper's Avatar
ExPACamper
Sounds like a good idea
Old May 5, 2015 | 04:04 PM
Pikachu's Avatar
Pikachu
Glow plugs are torqued to 14 ft/lbs, 168 in/lbs.
Old May 5, 2015 | 04:59 PM
ExPACamper's Avatar
ExPACamper
Thanks! Looks like a perfect thread to print out and lay on the engine bay with me when it's all open
jpcjguy
Sep 1, 2017 03:00 PM
tjbradney
20
May 18, 2016 07:26 PM
blueeyedfordguy
General Diesel Discussion
May 4, 2010 09:48 PM
farmdad
17
Jan 3, 2008 03:17 PM
rvfiver
Dec 31, 2003 03:21 PM
