Lets see those 5th wheels
Old Jan 9, 2017 | 01:48 PM
  #1006
87crewdually's Avatar
87crewdually
This one I found on Amazon and sits @ only 9.5".
Old Jan 9, 2017 | 02:23 PM
  #1007
brandon_oma#692's Avatar
brandon_oma#692
Thanks that may work well. thinking it would be the correct height if I mounted it in the gooseneck recess and did not use the legs. If I remove the head when not in use I would still have my clean flat bed. All I loose is the gooseneck ball. Just add a fifth wheel pin to the equipment trailer and I am set.
Old Jan 9, 2017 | 02:40 PM
  #1008
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
The B&W enables you the keep Gooseneck capability and remove the 5th wheel hitch easily........??
Old Jan 9, 2017 | 02:50 PM
  #1009
87crewdually
Correct. If he doesn't have a square removable ball it would require both kits as seen below.
Old Jan 9, 2017 | 02:51 PM
  #1010
brandon_oma#692
Sorry that response was to the Reese 30054. My flatbed does not have the square hole for the B&W. I could add the B&W gooseneck to use the flatbed companion though. B&W Turnover Ball Universal Flat Bed Weld On 5th Wheel Gooseneck Hitch GNRK1500 | eBay All my flatbed has under the hatch is a plate with a hole the ball is bolted to. It is a CM bed from before they used B&W hitches. I need to find out if the B&W flatbed companion would fit in my recess and be the proper height.
EDIT From etrailer the base of the flatbed companion is 18x18 I need to measure the recess in my truck.
Based on my boot it looks about 14"x14" and is sloped on the sides. The flatbed companion will definitely not fit in the recess. Hmmm
Old Jan 9, 2017 | 03:43 PM
  #1011
kla94's Avatar
kla94
Not much, but serves our purpose. 95 Coachmen Catalina with the 94 F350 IDIT.
Old Jan 9, 2017 | 04:04 PM
  #1012
RV_Tech's Avatar
RV_Tech
Often size and simplicity make life easier.
Steve
Old Jan 9, 2017 | 05:55 PM
  #1013
kla94's Avatar
kla94
Whole lot easier to park! We have had four kids and two adults in it.
Old Jan 9, 2017 | 06:32 PM
  #1014
brandon_oma#692
beautiful truck
Old Jan 9, 2017 | 06:45 PM
  #1015
kla94's Avatar
kla94
beautiful truck
Oh, you've done it now! I have more pics!
And seriously, thanks.
Old Jan 9, 2017 | 06:51 PM
  #1016
ATP Pilot's Avatar
ATP Pilot
Old Jan 9, 2017 | 07:58 PM
  #1017
Beast2017's Avatar
Beast2017
Camp land mission beach San Diego California
Old Jan 9, 2017 | 08:02 PM
  #1018
kla94's Avatar
kla94
That's NICE!!!
Old Jan 10, 2017 | 05:22 AM
  #1019
Jigger2020's Avatar
Jigger2020
Yes great looking fiver
Old Jan 10, 2017 | 03:31 PM
  #1020
MDSuperDuty's Avatar
MDSuperDuty
Is that a "campground".
Nice truck and rig!
