Transmission Problems Odd Symptoms Please Help
Old May 7, 2015 | 09:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've heard that, too. It isn't true.
There are no more drains than the torque converter and pan. If you want to get more fluid out, use THIS method.
Old May 8, 2015 | 04:28 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
As the viscosity of the ATF deteriorates, friction increases transferring mechanical energy to useless and destructive thermal energy. As thermal energy increases, viscosity further degrades, friction goes through the roof and a positive feedback loop is created that quickly brings down the source of the mechanical energy.
With that said, changing the ATF could only help by reversing the positive feedback loop which reduces friction and thermal energy while increasing mechanical energy. Failure at this point ONLY occurs due to component fatigue and stress which already occurred when the positive feedback loop was at it's maximum, and thermal energy and friction were at their greatest!
cubsfan96
Jun 19, 2018 08:01 PM
cutlass
Sep 7, 2013 10:52 PM
Buck Dharma Fan
Aug 18, 2013 08:10 PM
TurboTuff
15
May 27, 2009 09:55 PM
faceman1
1997 - 2003 F150
Sep 25, 2007 05:16 PM
