scanguage 2
Old May 1, 2015 | 03:04 PM
Georgejg13's Avatar
Georgejg13
scanguage 2
Hi all. my 05 decided not to start Tuesday. Ran fine Sunday to Deleware and back towing a trailer, about 320 miles....oh well. Can't seem to figure out right off the top of my head if its the IPR or not so i bought a scanguage 2 today and was trying to find out where to get al the x-codes to enter into it so i can fix my girl. Any and all help appreciated! Thanks!!
Old May 1, 2015 | 03:16 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Sg2 codes w/values
Here is a partial list of Xgauges with Ford's values.
KO=KEY ON LI=LOW IDLE HI=eHIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Old May 1, 2015 | 03:25 PM
69cj's Avatar
69cj
Just a quickie check, Have you checked the fuel reset behind the passenger kick panel. Have seen this be the cause twice under your circumstances. Shut it off for the night and next morning no start.
Old May 1, 2015 | 06:07 PM
dannyboy950's Avatar
dannyboy950
Totaly off topic but Rusty what are you useing to get so much information on a single post especially with that big a spaceing????
Old May 1, 2015 | 06:19 PM
Rusty Axlerod
That's copied from a previous post and pasted back to a note. When I post it, I just have to find the note on my iPad, click on the note/ select all/ and paste back into a open quick reply window. I also can flip through my notes without going to the web that way. I have a couple of notes that are all hyperlinks to threads here at FTE (and other places) so I can do the same thing to post links to anything I've made a note of. The first list of threads got so long I made another one so stuff would be easier to find.
Old May 2, 2015 | 02:00 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Check the links in my signature for how to enter Xgauges.
Old May 3, 2015 | 12:22 AM
Georgejg13's Avatar
Georgejg13
Thanks for all the responses!!
I did check the fuel shut off, it is ok.
We did get it to start one time and had a good snap-on reader hooked up to it. It would only throttle up to around 1000 rpm and at that time we had around 1200 psi of oil pressure reading at the ipr valve. The guy who ownes the reader said that should be much higher and said it was either the IPR valve or the HPOP. He said it should be up around 4,000 PSI or so while revved up to around 1500 RPM. Does that sound correct?
He reccomended taking the IPR out and checking the screen for a hole. Would a hole cause the problem?
I did just change the oil about 3,000 miles ago and put hot shotts stiction eliminator in it. Was worried that may have caused a problem....
I was in there about 40,000 miles ago and did the IPR, and the STC fitting and all the other reccomended upgrades in there. Was hoping I wouldn't have to go back in there.... The truck has 109,000 miles on it now.
When I did the repairs before, the IPR valve had a hole in the screen and the screen in the valley under the HPOP had a hole in it too. That was a sudden shut down while driving. Just thought this was odd that it ran fine the day before but now wont start. After it's little burst of running, now it won't even attempt to fire up, just cranks.
Will be programming the scanguage 2 tonight so I can try to figure it out tomorrow. Any idea if there is a program for the oil pressure at the injectors?
Thanks again for everyones help, I wouldnt even attempt all this without your help!!
Fal-308-Win
Feb 21, 2014 06:21 PM
goosehunta
Oct 24, 2012 11:52 AM
mtnxtreme800
Apr 10, 2012 10:32 PM
Twitche
Oct 17, 2004 02:18 PM
PaulR
1983 - 2012 Ranger & B-Series
Oct 5, 2004 08:50 AM
