help!!!! Another no start.
Old May 2, 2015 | 07:41 AM
forkhorn's Avatar
forkhorn
Sorry i dont have any real info for you guys, but i need a place start looking. Truck was fine yesterday and drove it all day. This morning she turns over, but quickly stalls out. She is on 05 with 165k. Oil, and fuel filters were all recently changed about 2 k ago. Ficm is at 48.injecters are all new about 10k ago. Stc fitting and dummy plugs were updated at about 120k.
Old May 2, 2015 | 07:48 AM
mustang_309's Avatar
mustang_309
What are the ICPV's at KOEO? Also how long ago has it been since the EGR valve was pulled and cleaned. Is it throwing any codes?
Old May 2, 2015 | 11:12 AM
forkhorn's Avatar
forkhorn
I'll check egr later today and try to get back with some numbers..... what is the prefered cleaner guys are using on the egr.... I seem to remember some controversy between carb cleaner and brake cleaner.
Old May 2, 2015 | 11:17 AM
mustang_309
I use carb cleaner, just be sure not to get it in the top ( electrical ) side of the valve and make sure you lube the orings with oil before you reinstall it.
Old May 2, 2015 | 01:51 PM
forkhorn's Avatar
forkhorn
I pulled the egr and it was filthy. Unfortunately its pretty wet in there too...... Not sure if its related to my no start problem , but its definitely a problem.
Old May 3, 2015 | 06:44 AM
78fordman's Avatar
78fordman
you have a egr cooler issue if the valve it wet. otherwise does it pop off at all or just crank over.
Old May 3, 2015 | 10:42 AM
BLADE35's Avatar
BLADE35
You have multiple problems
Did you ever test the spread
Old May 3, 2015 | 02:23 PM
forkhorn's Avatar
forkhorn
Update........ aside from my now apparent egr delete leaking, I am also missing my oil fill cap ( not sure how long i have been driving without it, or what happened to it. I am also not registering any oil pressure while cranking. Oil level is good on the dipstick, but im thinkink that debris may have contaminated the oil and is causing the lack of oil pressure...... aside from the obvious ( changing oil and filter) what else can i do if dust or debris has enterd the oil.
Old May 3, 2015 | 02:25 PM
forkhorn's Avatar
forkhorn
Yes, she did pop off at first, but not any more
Old May 3, 2015 | 02:28 PM
forkhorn's Avatar
forkhorn
My spread has been creeping up over the last couple of years and a new oil cooler has been on my list....... i didn't think this was as big of an issue if the egr cooler was deleted.
Old May 3, 2015 | 02:35 PM
05F250DSL's Avatar
05F250DSL
If your egr cooler is deleted you don't have a wet egr from coolant. It can be gooey sticky and not be from coolant entering the system. Unless someone did a stealth delete and it failed.
Old May 3, 2015 | 02:41 PM
forkhorn's Avatar
forkhorn
Not sure how to tell the difference between damp or gooey..... All i know is that i had some sludgey stuff down in there..... kinda like black toothpaste.
drzdave
Aug 6, 2014 03:11 AM
tonefordays
Jul 6, 2013 07:27 PM
craypc
May 13, 2013 07:32 PM
pmoney1983
Aug 20, 2012 07:03 AM
