x gauge codes
Old Oct 11, 2012 | 06:29 PM
goosehunta's Avatar
goosehunta
x gauge codes
were can i find the codes for all the xgauges for the 6.0?
Old Oct 11, 2012 | 06:34 PM
blueline970's Avatar
blueline970
You may try searching for a post on it by Blade35. If you can't find it I bet he will chime in or someone else.
Old Oct 11, 2012 | 06:35 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Sg2 codes w/values
Here is a partial list of Xgauges with Ford's values.
KO=KEY ON LI=LOW IDLE HI=eHIGH IDLE OR=OPERATING RANGE
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. Check when cold
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Barometric Pressure
TXD: 07E0221127
RXF: 046285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
Here is another BAR if the above one is not working for you. The one below works for me.
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Old Oct 11, 2012 | 06:57 PM
goosehunta's Avatar
goosehunta
thats great. thanks axelrod.
which of these should i watch when trouble shooting my studder in the mornings as well as my longer than normal but not crazy long cranks?
Old Oct 11, 2012 | 07:12 PM
BLADE35's Avatar
BLADE35
FICM
ICP
ICPV
IPR%
volt
Old Oct 11, 2012 | 07:14 PM
goosehunta's Avatar
goosehunta
kool thanks blade
Old Oct 11, 2012 | 07:15 PM
Rusty Axlerod
Sorry, 3year old grandson was tryin to help me type a minute ago when I posted that reply.
Here is another good list: https://www.ford-trucks.com/forums/a...8&d=1337911266
I would watch the FICM main power. Battery voltage, ICP, and IPR just to start with. And of course get the EOT and ECT gauges up and do a test drive to see where the coolers are also.
Old Oct 11, 2012 | 07:26 PM
goosehunta's Avatar
goosehunta
i run a sct tsx as gauges. i always watch my eot and ect delta. mainly under 8* delta. i had a scan gauge in my 99 ranger which is in need of a head job so why not use the sgII for a bit in the sd. just wanting to do some trouble shooting with my issues.
Old Oct 11, 2012 | 07:32 PM
BLADE35's Avatar
BLADE35
Thats great Rusty Train them young so when they get older you can hand him the part and Point him in the direction of the truck Git-R-Done LOL
Old Oct 11, 2012 | 07:35 PM
goosehunta's Avatar
goosehunta
lol thats right.
Old Oct 11, 2012 | 08:33 PM
Rusty Axlerod
Oh yea, he's loving the work bench. Earlier, I put a deep socket on a 1/4drive ratchet and showed him how to spin it around. He was having a big time until he got a little too wild with it and konked himself on the head . We have since switched to screwdrivers lol.
Old Oct 11, 2012 | 08:42 PM
BLADE35's Avatar
BLADE35
Maybe Santa can get him one those little Plastic Tool SetsSorrey
Old Oct 11, 2012 | 09:07 PM
Yahiko's Avatar
Yahiko
Sorry about the
Rusty I have two links for both of you
Bob the Builder Official Site | Online Games, Videos, Activities, Printables
Bob the Builder Toys - Character / Theme - Toys "R" Us
Sean Coke (The little ones are watching)
Old Oct 12, 2012 | 08:30 PM
goosehunta's Avatar
goosehunta
Boy this tread turned into a playhouse. Lol gota love the kids. I can't wait till my son is old enough to start learning. He's only 2 right now. My little girl who is 5 likes to help me wash the truck.
Anyway, I put the codes in for some of the xgauges. That is easy once you have the codes. Now my FICM is perfect. KOEO 48.5 and while cranking only went down to 47.5. And stayed there in that window while driving sometimes hitting 49.
Now my next question is with the icp, ipr. What is normal while starting, also what are these for? The icp is hpop right?
Old Oct 12, 2012 | 09:04 PM
BLADE35's Avatar
BLADE35
ICP= the Actual Oil Pressure
IPR= Is the Valve that controls the Pressure
So you need around 600 ICp to start the truck IPR will shoot High 77% Area
At Idel you will see around 580-620ICP and 22% IPR or so
Here is Ford specs
ICP 0 625.5 1400 - 1450 0 - 4045 PRESSURE (PSI) ICP Desired
Reading Left to right KOEO-Low Idel-High Idel (2500 RPM) Last set of numbers in this case 0-4045 is sensor Range
IPR # 14.84 24 40.60 0 - 50 PERCENT Injection Pressure Regulator
Same Deal Left to right^^^
I got alittle Creative LOL
