power to the starter
Old May 1, 2015 | 12:13 PM
davisrn94's Avatar
davisrn94
For some unknown reason my truck (1989 f150) is sending power to the little wire that goes to the starter selinoid every time the clutch is pressed any ideas? The clutch switch, the starter switch, selinoid, and starter are new.
Old May 1, 2015 | 12:32 PM
subford's Avatar
subford
I would say you have a bad ignition switch.
Old May 1, 2015 | 12:47 PM
David7.3's Avatar
David7.3
the clutch interlock switch should have a red wire with a blue tracer, that should only have power to it when the key is turned to crank position. if you have power there with just the key on, there is a problem, make sure you unplug the clutch switch when you check for power, The ignition switch is adjustable loosen the nuts and slide it up or down till you only have power when cranking.
Old May 1, 2015 | 01:24 PM
jas88's Avatar
jas88
Sounds like some "custom wiring" may be the culprit?
Old May 1, 2015 | 01:28 PM
davisrn94's Avatar
davisrn94
The wiring is still factory
Old May 1, 2015 | 01:30 PM
davisrn94's Avatar
davisrn94
The only switch that is connected to the clutch in any place has several wires coming from it and I've got the switch as far as it will go and still make contact to start
Old May 1, 2015 | 01:31 PM
davisrn94's Avatar
davisrn94
I have replaced it because of that problem and it didn't seam to help
Old May 1, 2015 | 01:33 PM
subford's Avatar
subford
There most likely is nothing wrong with the clutch switch as it only stops the cranking.
The ignition switch that David7.3 is talking about is on top of the column down by the floorboard.
Old May 1, 2015 | 01:34 PM
subford's Avatar
subford
Then you need to adjust it like it was talked about above.
Old May 1, 2015 | 05:34 PM
davisrn94's Avatar
davisrn94
I have adjusted it out all the way somebody said it could be the EEC
Old May 1, 2015 | 07:23 PM
subford's Avatar
subford
No the ECC has nothing to do with cranking the engine.
Old May 1, 2015 | 08:26 PM
davisrn94's Avatar
davisrn94
I'm at a loss I adjusted it all the way back and still had the problem so went and got another new one still same problem
Old May 1, 2015 | 08:31 PM
subford's Avatar
subford
Is the ignition switch plug melted?
Old May 1, 2015 | 08:33 PM
davisrn94's Avatar
davisrn94
It looked good when i took it off
sloburban
19
Oct 19, 2014 04:32 PM
rollinblacksmoke
Dec 23, 2013 06:11 AM
beckman
Aug 24, 2013 11:10 PM
53Trucker
Sep 26, 2005 10:03 PM
Ken2600
General Automotive Discussion
May 24, 2005 01:01 PM
