C6 questions
Old Apr 30, 2015 | 04:28 PM
mxer0022's Avatar
mxer0022
C6 questions
Hey guys I'm new to tranny troubleshooting and building and somewhat ignorant to symptoms. I have a few questions for you specialists.
First, can someone explain stall converters and what they do and the applications of each type?
Second, what is the hp limit of the stock input shaft on a C6? At What point do I wanna start thinking billet?
Third, I noticed that when I am going to stop the truck still tries to lurch forward a few times before I come to a complete stop but then it seems fine. Could this be a clutch issue? Which leads me to my last question.
Fourth, what is the best tranny rebuild kit that will beef up my tranny a bit more. Just want a little bit more reliability.
They tranny is in a 72 F250 with a basically stock 429. I'm gonna be pulling the motor and tranny this weekend because both need seals replaced and I am going to be rebuilding and porting my heads. The motor only has a 600 cfm carb so I will also be getting a 750 cfm for it.
Sorry for all the questions at once. Thanks guys.
Old Apr 30, 2015 | 06:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Every torque converter ever built is a stall converter. Saying stall converter by itself is meaningless. To make sense you need to specify high or low stall converter.
Stall is simply the maximum engine speed that can be achieved with the trans in gear, the vehicle not moving, and the go pedal on the floor. A rule of thumb is that stall speed should be a little below the engine's torque peak.
Old Apr 30, 2015 | 07:11 PM
mxer0022's Avatar
mxer0022
Ok that makes sense. Thank you for clearing that up for me.
Old May 4, 2015 | 10:16 AM
Fishin76's Avatar
Fishin76
Just make sure if you try that test that you do it for no longer than 15-20 sec. You risk overheating the TC, or blowing it out.
just sayin....
Old May 4, 2015 | 10:44 AM
Mark Kovalsky
I should have mentioned that. I recommend never running a stall test for more than 10 seconds, with at least one minute in park or neutral after that.
Tomget
15
Jul 31, 2012 08:05 PM
1977 f-350
Mar 23, 2011 03:35 PM
joe hoffman
18
Sep 12, 2006 06:27 PM
76 F-150 390FE
Jun 6, 2006 08:48 PM
78blueford
Dec 16, 2002 05:36 PM
