Need oil cooler gasket part # please!
Howdy all! First time posting on the Escape section of this forum so be gentle if I am asking a dumb question. My 2005 2WD 4 cylinder has a leak where the oil cooler mates to the oil filter housing. I took it apart and there is a rubber gasket that fits into a recess on the bottom of the cooler that seals to the filter housing that I can't seem to locate on any parts diagrams. I would like to order it online if possible as my nearest dealer is over an hour away, but if necessary I'll go there. It is not just a round gasket, but specifically made for probably just this one application. And I don't think RTV would work well. Has anyone replaced this part and have a source for it, or repaired it in a different way? Any help is appreciated. Thanks- Scott
Measure the dimensions and see if you can find an oil filter with similar. Remove the seal from the oil filter groove, and install in your adapter. Industrial supply houses may have O-rings that will meet your needs.
I went to silverstate ford, rock auto, and ford-parts and only found things on the last.
tom
tom
tom
tom
did you guys note this part:
http://www.fordparts.com/Commerce/Pa...d&model=Escape
Part Name: Engine Oil Cooler Gasket
Brand: Ford Genuine Parts
Part Number: 6840
Price: $8.85
Part Description: 2.3L Duratec-HE (145PS) - MI4
Part Number: 6840
Price: $8.85
2005 Ford Escape Engine Oil Cooler Gasket | FordParts.com
Part Number: 6840
Price: $8.85
Part Number: 6840
Price: $8.85
That is what I had been doing also, but it recently got really bad when the weather got really cold, so I am forced to deal with it. If it was my daily driver I could nurse it along for a few more years checking and adding oil, but it is my wifes car so thats not a realistic option I will probably bite the bullet and order another cooler tomorrow as I have searched high and low for just the gasket (or o ring or whatever it is called) but been unsuccessful at finding one. If any Ford executives or engineers are reading this- YOU GUYS SUCK! How could anybody design something with a gasket that can't be obtained to replace a leaking one? The obvious answer is so you can sell a $150 oil cooler instead of a $1 gasket!!! May the fleas of 1000 camels infest your armpits!
Take the thing apart, and get a picture of what you need. Maybe someone can recognize it and suggest a substitute.
Check on the adapter for a number and google. You may find that the adapter is made by Smedley Industries, just down the street, or is common in Europe, used on diesel and truck engines, and gaskets are available there.
The engine is not a native to USA, I believe it was an immigrant, so worldwide search may make sense.
If it part needed is indeed an O-ring, the checking with Granger & other industrial supply houses, or again, google with dimensions, might be successful.
If it is a molded gasket, depending on shape, etdc, use of some RTV to buttress the current material, where it has gotten compressed, may make it possible to re-seal without replacing.
Put up a picture, hopefully someplace besides photobucket.
tom
tom
tom
tom
http://thumbs2.ebaystatic.com/m/maUg...C_u0bg/140.jpg
Item #1 in the pic?
Looks like this in real life:
http://thumbs1.ebaystatic.com/m/m-iL...6CdESg/140.jpg
If so, the blue seal is the likely cause, and it is weird shaped. If removable, I'd take it out, knead it a bit, coat it with RTV and put it back together. If you manipulate the neoprene{?} then it sometimes will realize it is out of shape, and re-form back to where it should be. If you then add some RTV silicone, it will 'fill in the gaps' and as it sets, will seal.
I do not know how to stuff pictures in, so hope the link works, at least for a minute.
tom
Item #1 in the pic?
tom
Item #1 in the pic?
tom
Item #1 in the pic?
tom
