Engine won't turn after being installed
Old Apr 23, 2015 | 04:49 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Ok I am pretty sure I know the answer to this but was curious if anybody else might have an idea that I might have overlooked or something.
So I am just finishing rebuilding the 302 in my 88 F150 and just installed it. As I was installing it it was turning great but after I got it all bolted up and tightened I never checked if it would turn or not. A couple days later I put oil in it and went to turn the engine on the harmonic balancer bolt to sort of get the oil flowing through the block and I couldn't turn the engine at all.
I have put the transmission in neutral and left it in park and still can't get it to turn. I am thinking I didn't stab it right does this sound correct?
Is their any other ideas that maybe I can try first before I go through the hassle of stabbing it again this weekend?
Is it possible I ruined anything if I did stab it wrong?
The truck is a 88 F150 4x4 302 C6.
Thanks for any help
Trav
Old Apr 23, 2015 | 05:09 PM
rla2005's Avatar
rla2005
Yep...sounds like the torque converter is not fully seated. I am not a transmission expert but I would think you should be okay once you get it popped in another click or two.
Old Apr 23, 2015 | 05:14 PM
Redneckfordf2502002
Well the bell housing bolts are tightened all the way.
If this is the case I will get it fixed this weekend hopefully.
Would it be easier to drop the trans (or pull it back) or pull the engine?
I have never dropped an automatic transmission that is why I am not sure.
Trav
Old Apr 23, 2015 | 05:20 PM
rla2005's Avatar
rla2005
I would start with pulling the transmission back a bit to get your hands on the converter then attempt to get it fully seated.
Old Apr 23, 2015 | 05:22 PM
Redneckfordf2502002
Ok thanks that is what dad said but wanted a second opinion.
Trav
Old Apr 23, 2015 | 05:30 PM
Diesel_Brad's Avatar
Diesel_Brad
Hopefully you didn't ruin the pump or seal
Old Apr 23, 2015 | 05:36 PM
Redneckfordf2502002
Ya that is what I am hoping.
I am going to pull the trans back enough I can pull the torque convertor off and peak in their and see the seal if that is good put it together if not then I might be rebuilding a C6.
Trav
Old Apr 29, 2015 | 01:10 PM
Redneckfordf2502002
Sure enough was that the torque convertor wasn't fully seated. Removed the engine (was going to do trans then saw all the linkages I didn't want to mess with) set the torque convertor on slid the engine right on in and sure enough it turns with no problem at all.
I did pull the torque convertor off though to check if the seal and the torque convertor was in good shape and I didn't see any damage so hopefully the trans pump is fine.
Thanks for the help guys. That is one step closer to being able to drive my baby again. Over a year is way to long. LOL
Trav
Old Apr 29, 2015 | 05:37 PM
rla2005's Avatar
rla2005
Great news Trav! Hope the rest goes better for you.
Old Apr 30, 2015 | 03:00 PM
Redneckfordf2502002
Ya no kidding.
I have some plans that I am trying to figure out and I am wondering if I should post them here or make a new thread.
Trav
Old May 1, 2015 | 07:00 AM
dixie460's Avatar
dixie460
Originally Posted by Redneckfordf2502002
Ya no kidding.
Trav
Make a new thread with a general title (this one is specific to a problem) and post all your questions in there.
jdsgtball
Modular V8 (4.6L, 5.4L)
Apr 19, 2015 05:19 PM
anaconda
Engine Swaps
Jun 1, 2005 05:03 PM
MBenavdez
1978 - 1996 Big Bronco
13
Nov 12, 2004 11:21 PM
Boss300
Nov 12, 2003 10:44 PM
laka
Aug 10, 2002 10:19 PM
