engine won't turn
Old May 31, 2005 | 10:21 PM
anaconda's Avatar
anaconda
engine won't turn
i am putting the engine back in my 79 bronco. same engine took it out to use it for something, changed my mind and now i am stumped. the engine went back in fine everything just slid into place torque convetor on tranny engine lined up to bolts easy did it almost with no help. problem is the engine won't turn over. i took it out and put it back in same problem. went seperate engine and tranny work. engine was running fine 2 months ago when i pulled it the first time. sorry bout the long post
Old May 31, 2005 | 10:36 PM
Mike G's Avatar
Mike G
Help me out a little here. Will the engine not start? Does it not even turn at the crank by hand? If it is turning at the crank by hand when the tranny is not attatched, then you have a bind in the trans bolt up. Is the torque converter fully seated in the trans?
--Mike
Old Jun 1, 2005 | 05:03 PM
anaconda's Avatar
anaconda
yeah it won't crank by hand everyone i talk to says the torque convertor isn't lined up so i guess that must be the problem.
