*208* Burnt Marshmallow Thread
" Install the new block, jack up the axle to meet the new
block and make sure the center pin is in the axle. See
Photo 5. Note short side of block goes towards front
of vehicle."
Ok, rereading I see you had the shim thick side forward, not the block. So you basically made a flat(er) block.
I've been enjoying the Burnt Marshmallow. Finally was able to pull my 35' travel trailer camping and it did very well. Obviously the low end grunt was missing (with 3.73 ratio), but all-in-all it was great. I may need to run some airbags...as I think my tongue weight is a bit more than 12% of the overall weight of the trailer (9000lbs loaded). She squats, but not more than .5-1" negative rake. I would prefer no squat.
The vibration is still there. I'm thinking its a surface finish issue with a spider gear/s in the rear axle. I was not able to hear/feel it while towing my trailer.
I still haven't bought any wheels/tires yet. The cost of 20's with good tires is laughable.
Thanks for the nudge to jump back online. I will be present more often now that things are settling down with kids sports and school.
The vibration was Burnt Marshmallow telling you it wants to work
How long did you go out camping, and where did you go? Unless it's a secret
