shake from 45 up
Old Jul 12, 2006 | 06:55 PM
kpmalone's Avatar
kpmalone
shake from 45 up
I have had my 2005 for almost a year now. My truck will start to vibrate around 45 mph unloaded. Once I hit 80 mph, the vibration is not there anymore. When I have my truck loaded with a trailer, the vibration is not as bad but is still there once I hit 80. Now, The only reason that Ikeep mentioning 80mph is because I amjust curious as to when the vibration will stop. I have had it back to the dealership and they told me that is was my tire balancing( this was when I put 305/55/20 tires on it). I than sold those tires and went back to the factories. Vibration still there. I have just recently put 295/75/17 on. I visited a different dealership about the problem. They told me that it was my tire balancing until I told them about towing a trailer. They than said it could be a driveline problem. I am just wondering if anyome is having this problem with their truck and what could be done to fix it.
Old Jul 12, 2006 | 07:04 PM
FTE Trigger's Avatar
FTE Trigger
Oh my....
This seems to be one of the more popular "longer thread topics"...
I'm sure a few members oughta chime in here shortly.
You may also want run a search on ... Vibration, shudder, high-speed vibration and other combinations.
There should be "few" threads that were previously started...
Old Jul 12, 2006 | 07:15 PM
FTE Trigger
Old Jul 12, 2006 | 09:47 PM
1979FordF-250's Avatar
1979FordF-250
It sounds like it would first be the tires and wheels need to be balanced, but if that has already been done than you might want to have the driveline or the rearend checked out. Also make sure the front end is all balanced.
Is it 4X4?
Old Jul 13, 2006 | 02:37 AM
FTE Trigger
Lightbulb I Forgot somt'....
I Forgot to mention the Recalls and TSB buttons up top if you havn't found'em already...
Mentioning that... I had some time on my hands at the plant today and wrangled up a few (in link form)...
Tire/wheel Runout
https://www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=05-26-24
Shudder/Vibration on Moderate to Hard Acceleration
https://www.ford-trucks.com/tsb/full...hp?tsb=05-13-1
1st Order Vibration From the DriveLine at Highway Speeds
https://www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=04-25-8
Vehicle/Steering Wheel Vibration at 50mph (80km/h) or higher- Steering wheel nibble at 65mph (105km/h) or Higher
https://www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=04-25-7
Audible Driveline Moan above 45mph (72km/h) During acceleration or coasting- Vehicle Built 8/20/2004 to 10/4/2004
https://www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=04-23-10
Please Let Us know what you come up with...
Old Jul 13, 2006 | 08:04 AM
FTE Trigger
ouhh...and I forgot... Welcome to FTE!...
Old Jul 13, 2006 | 04:39 PM
tjames001's Avatar
tjames001
It could be the parking brake hanging up, this has caused a vibration problem for many f-150 owners.
You can check to see if the drum is hot to the touch however this may be hard to judge given that the disc and drum are integral.
Probably the best way would be to remove the rear wheel and caliper, then that disc should come off easy, if it doesn't it's probably because those shoes are tight against the drum... worth a look, just a process of elimination. good luck
Old Jul 13, 2006 | 08:40 PM
jdwheels's Avatar
jdwheels
Just got mine back from dealer... new drive shaft, and some sort of vibration dampner installed on the rear frame. smooth as glass again. mine vibed at 45 and real good at 70
Old Jul 13, 2006 | 11:19 PM
Champ198's Avatar
Champ198
I had steering wheel nibble and vibration in my '05 F150 Lariat. I took it a Goodyear dealership that had some new balancing equipment and the personnel trained to use it. My truck is smooth as glass now. It totally changed my outlook on owning the truck.
Old Jul 14, 2006 | 01:07 AM
2004 Screw's Avatar
2004 Screw
I would say its the drive shaft
Old Jul 14, 2006 | 06:20 AM
Palaminomike's Avatar
Palaminomike
Had the same problem with my 2004. Ended up with a new ring and pinion to get rid of it.
Mike
