steering wheel
Old Apr 18, 2015 | 12:17 AM
69issofine's Avatar
69issofine
steering wheel
i was putting on my steering wheel the other day in my 69 f-250 camper special and couldn't get it to go flush,there was a 1/8 in gap between the steering wheel and the colum so just kept on tighting to try to get ride of the gap,still haven't got ride of the gap but the nut is all the way down and turns freely and won't come off. am i screwed or what i am going to try to get the nut off without breaking anything . i think i will change the signal switch while i am there,found out you can't get a good switch in a wrecking yard. i got bthe old switch all hooked up except the little two terminal plug in which i guess goes to the rear lights mine was missing on the old switch.
Old Apr 18, 2015 | 12:18 PM
JEFFFAFA's Avatar
JEFFFAFA
Locate a "nut splitter" tool. If bolts and nuts get rusted around your town in WA then someone will carry it. Sears,Ace,Home Depot,Lowes,etc. Use it to remove the nut. Now question is which threads are stripped? The shaft's or the nut's?
What's wrong with a 1/8" gap?
Old Apr 18, 2015 | 12:57 PM
69issofine's Avatar
69issofine
i wasn't sure how much the gap was suppose to be and don't work on your truck when you are angry you just mess things up.
Old Apr 18, 2015 | 04:51 PM
HIO Silver's Avatar
HIO Silver
A 1/8-inch gap would have been correct.
Did you know that loosening the steering tube's clamp from under the dash also allows a lil bit of adjustment?
Old Apr 27, 2015 | 08:07 PM
69issofine's Avatar
69issofine
i got the nut off today but stiil couldn't get the steering wheel off,probably the only time it will come off is on the freeway at 70 mph,i think i need to go get one from the wrecking yard it is only 25 bucks if i can find one.
Old Apr 27, 2015 | 08:24 PM
gangstakr's Avatar
gangstakr
You should test that theory when you go to the wrecking yard.
Old Apr 27, 2015 | 09:23 PM
HIO Silver's Avatar
HIO Silver
'Time to go to Autozone for a $10 steering wheel puller kit.
Old Apr 28, 2015 | 11:30 AM
orich's Avatar
orich
Finding nice steering wheel in the PnP JY is a great score.
Simple things to learn a long the way of life if it won't go on or off.
1. get a bigger hammer.
2. Keep tightening with a wrench till it goes on or snaps.
3. Looks things over before removing.
4. have a manual for the vehicle your working on.
5. Correct tools like a TQ wrench
6. Ask a friend, if no friends keep hitting it until it breaks off.
7. Buy a whole new part.
Orich
cabloom300
Jun 24, 2010 10:41 PM
bishopgeer
Sep 11, 2009 08:05 AM
dude74crew
Mar 28, 2008 12:21 AM
tgowers
Jul 20, 2006 02:28 PM
poffutt
1978 - 1996 Big Bronco
Jun 7, 2005 06:13 PM
