Mine was on so tight what I had to do was put the puller on and have someone pull up on the wheel and then hit the main bolt in the puller. Most bolts that come with a puller are soft so you don't strip out the threads of what you are pulling but care should be taken but I had to smack it several hard good ones to break it free.
Use some anti-seize when you put it back on.
