steering wheel nut...
Old Jul 20, 2006 | 01:18 PM
tgowers's Avatar
tgowers
i tried once very briefly to straighten my steering wheel by loosening the nut, but the wheel wouldn't move.... is there something i'm missing? again, i tried only briefly, i didn't spend much time messing with it. thanks
Old Jul 20, 2006 | 01:46 PM
4Cammer72's Avatar
4Cammer72
usually a crooked steering wheel is an alignment adjustment. if you just want to adjust the steering wheel itself you need to loosen the nut until its flush with the top of the threads and while pulling on the wheel with your knees and one hand, smack the nut with a hammer a time or two and it'll pop off. then completely remove the nut and set the wheel in the position you want and tighten everything back down.
Old Jul 20, 2006 | 01:56 PM
tgowers's Avatar
tgowers
ok thanks, the truck tracks straight as an arrow..... no alignment problem.... just crooked, so i will do that. thanks a lot
Old Jul 20, 2006 | 02:24 PM
Mil1ion's Avatar
Mil1ion
Be careful you don't break the S.wheel or smack yourself in the forehead.
The FTE ambulance is out on a call right now
Old Jul 20, 2006 | 02:28 PM
seventyseven250's Avatar
seventyseven250
A steering wheel puller may save you some bruises here. Very simple to use and not expensive.
SultanGris
6.7L Power Stroke Diesel
41
Jun 22, 2017 10:43 PM
regret
36
Jan 13, 2017 06:59 PM
The Tiger
Feb 16, 2016 09:32 AM
1978ShortboxF-150
Nov 22, 2015 04:43 PM
buckeyeinatl
Oct 29, 2014 07:30 AM
