1958 F100 engine ID
Old Apr 17, 2015 | 04:11 PM
Boon's Avatar
Boon
1958 F100 engine ID
I have a 58 f100. The vin indicates it came with a 6 banger. It currently has a v8. It has the arm burner exhaust crossover manifold. I would like to know if there is a way to determine which v8 it is. Thanks
Old Apr 21, 2015 | 02:58 PM
mcdonaldm's Avatar
mcdonaldm
do a google search for y block identification and a couple of sites should pop up that will help you decode the casting number on the block and heads that should help id the engine size. (assuming someone put a y-block in there. the valve covers are held down by centre bolts)
rgds
Mike
rustydicksimports
Nov 30, 2014 07:56 PM
Aekisu
Jul 1, 2006 06:44 PM
Murph2006
Oct 25, 2005 08:27 AM
OldFords
Sep 26, 2005 05:42 PM
dover
Mar 1, 2001 09:55 AM
