Engine size help?
Old Oct 19, 2005 | 05:02 PM
Murph2006's Avatar
Murph2006
Engine size help?
I have a 64 F100 2wd. the engine is not original because the vin calls for a 6cyl. I have the block casting number, so my question is: Can anyone identify this engine for me? it would be greatly appreciated. the block number is B5AE-601-A
Old Oct 19, 2005 | 07:43 PM
pntrbl's Avatar
pntrbl
Just a wild shot over the part number. B5 would indicate the block design was released to production in 1955 and in that era it'd just about have to be a Y-Block. 272-292 and 312 are the various flavors and the easiest way to ID a Y-Block is the exhaust crosses over in front of the motor. Driver's side to passenger side I believe.
Old Oct 19, 2005 | 08:01 PM
Murph2006's Avatar
Murph2006
Ok and how would i determine the Cubic inches of the engine?
Old Oct 19, 2005 | 10:08 PM
BobbyFord's Avatar
BobbyFord
I don't believe the 312 was introduced until '56. At least in passenger cars.
Old Oct 20, 2005 | 06:14 AM
jowilker's Avatar
jowilker
Murph2006, Welcome to FTE The best truck show on the net.
The 64 used a front rear mount system, and in 65 started with the side mount.
Does you engine mount front/rear or side?
John
Old Oct 20, 2005 | 08:08 AM
312's Avatar
312
are you sure thats not b9ae.that would be a 59 or 60 block.can be 292 or 312.
Old Oct 20, 2005 | 09:17 AM
Mike G's Avatar
Mike G
Check me if I'm wrong here, but the Y-Block motors also had the distributor mounted on the back side of the manifold
In order to check displacement, you will need to know the measurements of the stroke and the bore. I am not too familiar with the Y-block, but if the stroke was different between the 292 or the 312(the experts can chime in here), at least you can use the one number to get you closer to the motor you have.
--Mike
Old Oct 24, 2005 | 07:27 PM
Murph2006's Avatar
Murph2006
the number on it is B5AE for sure, i really dont want to take the engine apart until a get a building up to put the truck in, so i guess i will have to wait but if anyone else can help me it would be great. i appreciate the help guys. Murph
Old Oct 25, 2005 | 08:27 AM
312's Avatar
312
go to www.ford-y-block.com you will find engine id there.
