Aerostar Ford Aerostar
Changing shift cable
Old Apr 14, 2015 | 05:05 PM
willowbilly3's Avatar
willowbilly3
Before I dive in, just wondering if anyone had any tips on changing the shift cable on my 97. I tried a search several different ways and came up with nada.
Old Apr 15, 2015 | 04:43 AM
Jose A.'s Avatar
Jose A.
Why do you think the cable is bad??
to replace: set the shifter arm into PARK;
get on your back to pry off the fitting on the shift column end, using a "Y" screwdriver, then you get under the van and do the same. Removing the driver's seat makes the job a lot easier.
then you start to push the cable from the cabin to the ourside, a helper under the van pulls, as you help guide the cable out. There is a rubber grommet behind the accelerator pedal that seals the entry hole at the transmission tunnel.
before you do all this, study the angle and curve that the cable makes after it enters the cabin, and under the van; The cable forms a "J" curve before it reaches the shifter.
Connect the shifter end first, in case you have to twist the cable. Connect the transmission end last.
Old Apr 15, 2015 | 06:16 AM
willowbilly3
Thanks.
I think it's bad because it quit shifting, shifter wouldn't go into park, pretty much wouldn't move at all. I unhooked both ends, shifter makes full travel smoothly, lever on transmission makes full travel as it should and I can't move the cable with both ends unhooked. I definitely wanted to make sure it wasn't the shift tube in the column. I had to change one of those in my old Aerostar.
Old Apr 15, 2015 | 07:34 AM
Jose A.'s Avatar
Jose A.
in my '97, the shifter became very wobly and it turned out to be the plastic bushings in the shifter tube.
Old Apr 18, 2015 | 11:38 PM
KhanTyranitar's Avatar
KhanTyranitar
If it won't move at all, look at the brake switch. If the brake switch isn't working, then you can't shift out of park.
Old Apr 19, 2015 | 05:51 AM
Jose A.'s Avatar
Jose A.
the service manual has a procedure to shift out of park with a bad pedal switch
RIKIL
Feb 20, 2013 10:06 AM
msfprobass
1978 - 1996 Big Bronco
Jan 24, 2012 05:05 AM
imlowr2
Jan 1, 2006 09:04 PM
toolman7715
1983 - 2012 Ranger & B-Series
Mar 2, 2004 08:41 PM
