97 7.3 tranny problems
Old Apr 12, 2015 | 06:11 PM
nelsen94's Avatar
nelsen94
hey guys im new to this site but i just bought my 3rd 97 ford f250 hd powerstroke and im having problems with the trans it will not shift smooth its alomost like its partially shiftting into the next gear then down shifts and trys to shift again. this only happens when im kinda getting on it. the truck has 312,xxx on it with a ts 6 position chip and 36 inch tires. the trans is the e40d not sure if its the shift selinoid or what. any advice would be great. and yes the fluid is full and clean no slip codes... not sure if these trucks throw a slip code???....
Old Apr 12, 2015 | 09:26 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
I would take the chip out and see if it still does it. Welcome to the forum
Old Apr 12, 2015 | 10:29 PM
fordpride's Avatar
fordpride
Is the OD light flashing
Old Apr 17, 2015 | 01:20 PM
nelsen94's Avatar
nelsen94
thanks guys
I put the chip on stock and still having the same problem and the OD light is not on. Also I just noticed that it doesn't shift into OD until 50 mph otherwise it hold 3rd
Old Apr 17, 2015 | 01:24 PM
fordman67's Avatar
fordman67
Has the psom been recalibrated for the larger tires.as in is the speedo correct?
Old Apr 17, 2015 | 01:39 PM
nelsen94's Avatar
nelsen94
What is the psom and the speedo is rite on
Old Apr 17, 2015 | 01:50 PM
madMatador78's Avatar
madMatador78
Is it shifting somthing like this?
Mine did this after I put the chip in, I think it has something to do with the tunes on the chip.
Old Apr 17, 2015 | 02:01 PM
nelsen94's Avatar
nelsen94
It kinda does that but no where near that bad and mine does it even after I put it in stock mode
Old Apr 17, 2015 | 02:12 PM
madMatador78
Yeah it doesn't matter on mine either. Take the chip out and if that fixes it, then thats the problem.
Old Apr 17, 2015 | 02:42 PM
fordpride's Avatar
fordpride
Putting it in stock isn't taking it out.
Take it out and see what happens.
Old Apr 17, 2015 | 07:23 PM
fordman67's Avatar
fordman67
If the speedo is correct then nm.
Mine gets all confused at wot.....it ain't gonna get any better lol
Old Apr 17, 2015 | 10:35 PM
nelsen94's Avatar
nelsen94
Ok I'll take the chip out completely tomorrow and see what happens
Old Apr 18, 2015 | 05:48 PM
nelsen94's Avatar
nelsen94
So I took the chip out and it still does the same thing. Any other ideas would be great
Old Apr 18, 2015 | 06:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It can set a slip code. The slip code can only set in fourth gear when the converter is supposed to be locked.
Does it do this at every shift, or just certain gears?
Old Apr 18, 2015 | 07:59 PM
nelsen94's Avatar
nelsen94
It does this threw every gear depending on how hard your on it
76250_4x4
Sep 18, 2017 07:18 AM
Zeropowerstroke99
13
Jun 9, 2014 10:42 AM
willmcgraw78807
May 21, 2014 08:27 AM
danlemieux1
Mar 9, 2008 07:21 PM
pyle129
Jun 17, 2007 07:54 AM
