Brake Problem?
Old Apr 12, 2015 | 03:12 PM
Ford Trimotor Pilot's Avatar
Ford Trimotor Pilot
Cool Brake Problem?
On first application pedal goes almost to floor but brakes still work. Pump once and pedal comes right up. Tried bleeding and didn't help?
All new brakes all around. Disc on front drum on back:
Any ideas?
Thanks
Mike:
Old Apr 14, 2015 | 02:47 AM
UNTAMND's Avatar
UNTAMND
Are the rear brakes adjusted correctly. Tighten them up so you have a healthy drag when turning tire by hand.
Have someone pump up the brakes while you watch the rubber hoses. They will flex a little, but if they are bad, they will flex a lot or bulge.
Old Apr 14, 2015 | 03:04 AM
EgoTrip90's Avatar
EgoTrip90
this may be a stupid question but did you bleed them after replacing them?
Old Apr 14, 2015 | 04:31 AM
White 97 xlt's Avatar
White 97 xlt
Adjustment is a very good idea.... if you have a solid pedal (not spongy) with that one pump. Do you have a firm pedal?
Egotrip, It doesn't look like you even read his post... To help you understand, I highlighted the part you completely missed....
Any ideas?
Thanks
Mike:
Old Apr 14, 2015 | 05:03 AM
ng19delta's Avatar
ng19delta
I'd check the brake booster & the vacuum line to it, as well. If it is not functioning, you revert to manual brakes- which is what it sounds like has happened...
Scott
Old Apr 14, 2015 | 08:25 AM
animator's Avatar
animator
Sounds more like air in the MC or somewhere in the line that isn't fully bled out.
Old Apr 14, 2015 | 12:19 PM
Mike1's Avatar
Mike1
My sons friend just had the same problem on his mustang. Come to find out, he and my son had been bleeding from the hose where it connects at the caliper instead of using the bleeder valve. They were afraid they would break the bleeder so they thought they could cheat. I worked it loose for them and all it took was 2 pumps to get the air out.
Old Apr 14, 2015 | 12:56 PM
snowdog79's Avatar
snowdog79
Still air trapped in the system. When you bled it, did you start from the right rear?
7.3dieselMike
Jul 30, 2014 03:00 PM
frogkid11
Oct 30, 2012 10:53 PM
Magic
Jan 27, 2007 10:29 AM
muscletruck7379
Apr 16, 2005 09:47 PM
DVigeant
Mar 5, 2005 11:12 AM
