On first application pedal goes almost to floor but brakes still work. Pump once and pedal comes right up. Tried bleeding and didn't help?
All new brakes all around. Disc on front drum on back:
Any ideas?
Thanks
Mike:
Adjustment is a very good idea.... if you have a solid pedal (not spongy) with that one pump. Do you have a firm pedal?
Egotrip, It doesn't look like you even read his post... To help you understand, I highlighted the part you completely missed....
Originally Posted by EgoTrip90
this may be a stupid question but did you bleed them after replacing them?
Any ideas?
Thanks
Mike:
I'd check the brake booster & the vacuum line to it, as well. If it is not functioning, you revert to manual brakes- which is what it sounds like has happened...
My sons friend just had the same problem on his mustang. Come to find out, he and my son had been bleeding from the hose where it connects at the caliper instead of using the bleeder valve. They were afraid they would break the bleeder so they thought they could cheat. I worked it loose for them and all it took was 2 pumps to get the air out.
