Sponsored by: Kumho
bad brake pedal
Old Jan 19, 2007 | 06:38 PM
Magic's Avatar
Magic
bad brake pedal
My pickup has all new brake lines,wheel cylinders,shoes,master cylinder,brake booster and Vacc. hose. I bleed the brakes using a hose and a coke bottle to check the bubble bleed off on the cylinders. With all the all out of the lines, I have great brakes and a full pedal. It even holds great long as I am applying pressure. But release the pedal and try again,the pedal almost goes to the floor. After pumping again,the pedal is up and holds. What do you think the problem is,or could be ? I know a person can buy new stuff,finding out its no good also. Someone said I might have a line leak,but none show a leak. Besides it there was a leak, when you pump it up it would know be solid and hold. The pedal would go down.
Old Jan 19, 2007 | 07:20 PM
Bdox's Avatar
Bdox
Do you have drums in the rear? If so, make sure all the return springs are good, lube the backing plate and adjust them manually.
Old Jan 20, 2007 | 09:18 AM
mark a.'s Avatar
mark a.
Are the back brakes adjusted up tight ?
Old Jan 20, 2007 | 02:34 PM
Magic's Avatar
Magic
The truck has 4 wheel drum brakes new shoes, wheel cylinders,and springs. Also the front and rear brakes are adjusted tight,any more the drum won't turn. Its a puzzle to me. If I pump it 2 times,it will have a full pedal. Also hold that away until,I take my foot off. Then if I just push once it will go to the floor. Pump 2 times and I have a full firm pedal.
Old Jan 20, 2007 | 03:41 PM
Bdox's Avatar
Bdox
If that's the case, your new master cyl is bad.
Old Jan 20, 2007 | 04:04 PM
ubereal2's Avatar
ubereal2
Smile Air
Sure sounds like there is air in the system to me.
You're best way to bleed the brake system is to have another person with you. Make sure you keep the master cylnder full of clean fluid.
One person to open and close the bleeder valve between every pump.
Start at the right rear, then the left rear, right front, then the left front.
Make sure all brake shoes are adjusted properly. Should have just a little bit of drag when spinning the wheels.
Bob
Old Jan 21, 2007 | 10:48 AM
mark a.'s Avatar
mark a.
Did you try bleeding the master cylinder ?
Old Jan 21, 2007 | 11:33 AM
Magic's Avatar
Magic
The master cylinder was benched bleed,and bleed after installed. Also I did have someone pumping the brakes while I bleed each of them,starting with the right rear. After each wheel the master cylinder was refilled,never got more then half low on fluid.
Yes I used only new clean fluid a 32 oz bottle and a half of another bottle.
Old Jan 21, 2007 | 03:53 PM
mark a.'s Avatar
mark a.
Is it a single or dual piston caliper ? Maby a piston is sticking. Slide sticking.
Old Jan 21, 2007 | 04:29 PM
Magic's Avatar
Magic
Sory Mark, as I mention earlier this is a 4 wheel drum brake truck. So its got 4 wheel cylinders not calipers.
Old Jan 21, 2007 | 07:58 PM
Bdox's Avatar
Bdox
New means new, it doesn't mean good.
Old Jan 22, 2007 | 05:17 AM
stuart1's Avatar
stuart1
Did you adjust the rod from the booster to master cylinder?
Old Jan 22, 2007 | 04:31 PM
TryMe's Avatar
TryMe
Ok ! I have been reading what you and the guys wrote and I would like 2 give you my 2 cents. But first, I like to ask something. I'm thinking the guys are figuring its a later model truck 70s up , but not me. I think its old truck,pre 60 from what you say. Is it ??? If thats the case I have 2 both big early 50s myself. And the system is a little diffrent in the early models. Give me or us the year and size and I will explain. Tracy
Old Jan 23, 2007 | 04:29 PM
Magic's Avatar
Magic
Its a 1958 Ford F-600 292 V-8 if that helps.
Old Jan 27, 2007 | 10:29 AM
Magic's Avatar
Magic
Thanks Tracy and guys It was the copper washers,causing a very small leak. One had a very small bur. I replaced them this morning and bleed the system. Got great brakes. I did not even know the brake system had copper washers in it. It was so weird, I checked the whole system for brake fluid leaks,there was none. Does yours have the same system. Lots of brake lines,mine has 5 lines coming off of the master cylinder alone. Thanks again
IDIDieselJohn
21
Oct 18, 2015 06:38 AM
jrwhitey_2000
Nov 26, 2009 06:18 PM
gtuttle
26
Jul 22, 2009 08:13 PM
needshave
17
Feb 25, 2009 07:18 AM
LM14
20
Oct 22, 2007 08:40 AM
