EGT and NOX Sensor...KISS IT PLEASE
KISS IT...as in KEEP IT SIMPLE
Here is a simple request that maybe someone will be kind enough to help educate me.
I can read post after post of EGT Sensor failure that runs on for ever, many times being interjected with comments of "Pull that Crap off and forget about it" Which ain't exactly legal or worth deleting the drivetrain warranty over to me.
What I would like to see is a simple KISS *=(Keep It Simple Stupid) post or reply that gives the stock number of the EGT Sensor and NOX Sensor. A diagram of the exhaust system showing the location of each Sensor and listed by it's name IE: Bank 1 Sensor 1 and so one including the NOX Sensor location. I don't care if the diagram is hand drawn as long as it sticks with the KISS Principal and easy to understand.
Again, please don't clutter up the replies with "Dump It" post, just plain how to replace the sensors, where they are located, and the part numbers.
Is someone wishes to attach the "Error Codes" that would be a plus.
Maybe if it is kept to the basics it could be used as a "Sticky" for future owners to refer to rather than posting the subject over and over again.
Thank you for your assistance,
EO2SeaBee,
That was the kind of simple diagram I was speaking of. Simple black and white with well defined locations pointed out. I printed a copy and will keep it in the truck along with the list of codes that give the sensor location it directs to being at issue.
Painted Horse,
I will follow your suggestion and download the coffee table book, it looks like it is well illustrated and could be a wealth of information. Do you have a link as to where it can be obtained?
Thank you all for Keeping it Simple for a Simple minded individual.
Painted Horse,
Download it to your computer. The links to find it from time to time
CoffeeTable Books
CoffeeTable Books
EGT info
EGT roadside assistance kit, $60. Or you can wait an hour or 2 for a tow truck.
Temp Sensor, AC3Z5J213B, $34
Code reader, $24
BAFX Products (TM) - PIC18F2480 Bluetooth OBD2 scan tool (I have tested this one)
<o</o
ODB app, Torque lite $0
Codes;
P0544 - Exhaust Gas Temperature Sensor Circuit - Bank 1 Sensor 1
P0545 - Exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P0546 - Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P2080 - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor1
P2081 - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 1
P2084 - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor2
P2085 - Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 2
P20E2 - Exhaust Gas Temperature Sensor 1/2 Correlation Bank 1
P20E3 - Exhaust Gas Temperature Sensor 1/3 Correlation Bank 1
P20E4 - Exhaust Gas Temperature Sensor 2/3 Correlation Bank 1
P242A - Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 3
P242B - Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor3
P242C - Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 3
P242D - Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 3
P242E - Exhaust Gas Temperature Sensor Circuit Intermittent/Erratic Bank 1Sensor 3
P246E - Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 4)
P2470 - Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 4)
P2471 - Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 4)
P2478 - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 1)
P2479 - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 2)
P247A - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 3)
P247B - Exhaust Gas Temperature Out of Range (Bank 1 Sensor 4)
Sensor order, 1 is 1st from turbo, 4 is last before tail pipe
13mm wrench (already in your truck, right?)
for some more info, see page 117. This will allow you to test a sensor with a cheap $3 multi meter (also already in your truck, right?)
https://www.motorcraftservice.com/vd...DOBDSM1401.pdf
"The Exhaust Gas Temperature Sensor is a PTC (positive temp coeff.) Thermistor that provides an analog output voltage proportional to the exhaust gas temperature."
Code reader, $24
<o</o
Codes;
Yes it is part of the '15s and always a possibility with our trucks. My problem with Ford is that our trucks shut down! No matter where, no matter what you are doing! I carry spare sensors, 13mm wrench, list of codes and a scanner to clear the codes to get the truck moving again after I change them out. You should also get under the truck, while new, and unscrew the sensors and put anti-seize on the threads that will enable you to get them out when/if they fail.
Also, here is another pic of the exhaust diagram. With year model '13 and above, all are the same like the previous years pickup models.
Another thing. On my 2015 there is a sensor aft of the rear axle right at the top of the exhaust pipe. This is new.
It irritates me to find it because I wanted to install the AFE DPF-back pipe I had on my 2011 truck. I started to gear up to do the install and saw that dang sensor and proceeded to give the pipe away..........
Thanks Doug. I will likely get a new pipe some day. They're stupid expensive for what they are so I'm not in a hurry to buy one right now. The only reason I want one is to quiet that dang blow dryer sound.....
