PATS failure Code 16 - dtc9232
Old Apr 16, 2015 | 04:10 AM
HappySailor's Avatar
HappySailor
Originally Posted by Skauber
No luck in fixing the dodgy wires you found? If you fixed that, maybe you wouldn't have to deal with the whole flashing and reprogramming thing...
I tried following connections from the antenna, and gave up when I got buried... If I could get some more info on the wiring diagram and component locations I would do some continuity testing... Otherwise, I really don't want to be stranded... I drive this truck all over the country...
Originally Posted by projectSHO89
The PATS system is solely an integration of the coded key(s) and the processing of that encoding to permit the engine to operate. There is no discernible interaction between the rest of the vehicle's factory-installed perimeter security system and the PATS functionality.
Totally makes sense now.... TWO complete and separate systems...
Thanks!
rch10007
Dec 20, 2014 04:41 PM
bitco
Jul 8, 2013 07:32 PM
pete68
13
May 15, 2006 11:39 PM
tufstuf
Electrical Systems/Wiring
Sep 20, 2005 09:07 PM
rooptroop
May 30, 2003 01:37 AM
