Sponsored by: Real Truck
Towing problems
Old Apr 7, 2015 | 11:50 PM
lmatthysse's Avatar
lmatthysse
Exclamation Towing problems
First time poster, new to this format. I have an 05 350 crew, 6.0. auto, less then 40K miles. Turbo was serviced in the past and upgraded turbo half installed. Runs fine until I purchased a 5th wheel and towed it home. on long uphill grads it would intermittently start making a fan rev'ing up sound and I would lose speed. Turbo boost look strong @ 20-25 at 3k rpm but once on one of the last times it happed bad, I saw the boost drop to 0 for a short bit before snapping back. Once over the crest of a rise and the throttle let up, the fan sound would usually fade and the drive would engage normally. As it got worse and persisted, I would pull over for a minute and shut down and restart and run strong till another hill load, but mostly the longer hill loads would make it go. I fear the worst.
Old Apr 8, 2015 | 12:10 AM
clem1226's Avatar
clem1226
Kind of sounds like the engine cooling fan engaging as the engine heats up. These powerstrokes have huge fans and you can deffinatly feel and hear it when they fully lock up.
As to the boost issues..... I have no idea.
How big is the 5th wheel? How much does it weigh?
Old Apr 8, 2015 | 07:46 AM
lmatthysse's Avatar
lmatthysse
32' ~10K, not too big. Did not seem to be the weight, ran fine when it ran
Old Apr 8, 2015 | 07:54 AM
MC5C's Avatar
MC5C
You need to get an OBDII data gauge like the Scanguage II so that you can read your oil and coolant temps. If the temps get too hot it can cause the engine to de-power, but you would normally expect a wrench light to come on. The other common thing that causes a wrench light and lack of power is over boost.
Old Apr 8, 2015 | 10:36 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Coolant and oil temps are part of what drive fan operation, and can also cause the engine to defuel. Until you get a gauge and can read actual the actual ECT and EOT numbers, you'll be guessing.
Good reads:
https://www.ford-trucks.com/forums/96...used-6-0l.html
Ford Truck Enthusiasts Forums - View Single Post - Just bought 06 F350 FX4 6.0!!
https://www.ford-trucks.com/forums/13...eral-info.html
https://www.ford-trucks.com/forums/97...-pressure.html
6.0L specific forum and tech folder:
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
https://www.ford-trucks.com/forums/30...ch-folder.html __
These were related to a guy with a 6.0L plowing, not related to OPs situation but I didn't delete them in the original post:
Old Apr 8, 2015 | 10:48 AM
lmatthysse's Avatar
lmatthysse
Good feed back, Sounds like we are on the right track.
Boaterguy
6.7L Power Stroke Diesel
15
Jul 2, 2015 09:10 AM
Bob2626
Aug 14, 2011 03:35 PM
ArtVnTampa
Dec 2, 2010 02:16 PM
TXHillCountry
Dec 2, 2007 11:50 AM
JAMESR
Mar 7, 2006 11:22 PM
