Turbo Probs
Old Nov 14, 2005 | 03:18 PM
JAMESR's Avatar
JAMESR
Turbo Probs
I Have A 2005 6.0 Psd Automatic And Im Getting A Screaching Noise Around 24 Psi Boost When Loaded.
When Off Loaded It Just Makes A Quick Chirping Noise Between Shifts At The Same Psi
Some Times Cold I Think I Hear It Chattering At Idle On First Start Up
Normal Driving I Dont Notice Anything Different
Does Anybody Reconize This
What Do I Do
Old Nov 22, 2005 | 07:26 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Bump
Old Nov 22, 2005 | 04:03 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
are you sure that the screech just isnt the fan clutch engaging, and making the fan spin the same rev's as the engine? is the screech followed by a large howling sound? if so, thats the fan. the extra heat created at high boost (high EGT's), which leads to the entire engine being hotter, from more work. the engine decides it needs to cool down, and the fastest way is the fan.
oh and about cold-startup clatter, that is normal. diesel engines need HEAT to run. without it, not much is going to happen. as long as the clatter goes away in a few seconds to a minute, youre fine.
Old Nov 22, 2005 | 05:49 PM
drfdog's Avatar
drfdog
is there a loss of power? My friends 04 with 5,000 miles had to have the turbo replaced. But he felt a loss of power first.
Old Nov 22, 2005 | 10:01 PM
bocomojoe's Avatar
bocomojoe
When the fan engages on my '06 it's an entirely different sound than the fan on my '96. The first time I heard it go on I almost pulled off the road, then I realized what is was. Mine hasn't stayed on for very long (cycles off fairly quickly).
Old Nov 25, 2005 | 08:19 PM
JAMESR's Avatar
JAMESR
I HAVE 11000 MILES ON THE TRUCK AND THE FAN SEEMS NORMAL
THE TURBO WINE AS IT SPOOLS UP CHANGES FROM NORMAL TO A SCREACHING SOUND LIKE THERE MAY BE A BAD BEARING STARTING
THERE IS NO NOTICEABLE POWER LOSS
I CHANGED OIL VISCOSITY FROM A 5W40 ROTELLA SYN TO 15W40 CASTROL SYN AND THE PROB IS STILL THERE A LITTLE LESS BUT STILL THERE
THE NOISE IS A VERY HIGH PITCH SCREACH LIKE 30000 RPM TO 40000 RPM
NOT 2-3000 RPM NOISE
LIKE THE NOISE ON A IPS BLOWER ON A T701C TURBINE ENG WHEN THEY GO BAD(H-60 HELO ENG)
HAS THE DEALERS BEEN GIVING YOU GUYS PROBLEMS CHANGING THE TURBOS OUT
THE TRUCK GOES IN ON THE 28TH
ANY AMMO AGAINST THE DEALERS WOULD BE APPRECIATED
Old Nov 26, 2005 | 07:36 AM
kb1aah's Avatar
kb1aah
Thumbs up
My '05 made a screach as well between 50-55mph at wide open throttle. The latest PCM update took care of the noise.
Make sure you have the latest software.
Old Nov 26, 2005 | 09:40 AM
F250Wheels's Avatar
F250Wheels
A turbo can make A screaching noise if it's going out, the turbo vanes start hitting the housing. Had this happen on my sand rail.
Old Nov 29, 2005 | 10:31 PM
JAMESR's Avatar
JAMESR
Talking Turbo Prob Fixed
It Took Them Two Days With The Truck But They Are Finally Changing The Turbo With A Upgraded Turbo From Ford
Thank God
They Said It Had Bad Bearings
Old Feb 2, 2006 | 05:11 PM
unclmike's Avatar
unclmike
Angry Turbo needs to be replaced!
Hello fellow Diesel mainia persons.Today I was informed that the Turbocharger in my 2004 6.0 PSD CC with 15,376.0 miles will have to be replaced.The thing that is odd about it is the truck is keep indoors @ 60 degrees here in New York and has not seen any real work except for pulling a 24 ft car trailer empty for approx 200 miles.The truck was fine the last time it was used.Then the next time I went to use it ( Same tank of gas and very mild day@ 52 degrees),it had no power at all.Their was no sign of a problem like noise or smoke but as I slowly gave it the gas it just wasn't making any boost .it felt like I was driving a 6cly or something.So I made appointment to have it checked out.In addition no check engine light at this time.3 days later Go to bring the truck to dealership and problem is completley gone.It drove fine on the hiway so I turned around and went home after cancelling that appt.Then about a week later I brought it in to a station for State inspection and on that trip it seemed to be slow of the line and finally coded with check engine light.Still drove fine and at highway speeds but I could tell from dead stop that it seemed like a bit to much turbo lag.Anyway I drove it in to dealership and they said turbo is sticking.They will order a rebuilt unit and call when its in
Old Feb 3, 2006 | 12:28 PM
BassCat's Avatar
BassCat
Thank God
You might ask them for a part number? 5C3Z6K682K-CA is probably what you have now. I'm not aware of an up-graded turbo for an 05-06. The 05 turbo is an up-grade from the 04. You might be getting a rebuilt 05 or a new 05 like you already had.
Old Feb 3, 2006 | 02:03 PM
dPrasse01's Avatar
dPrasse01
I wish the 3 different dealers I took my beast to would have listened to me and the others on this board ... a new turbo would have allowed me to keep my 04 ...
Congrats on your GREAT dealer !
Old Feb 3, 2006 | 09:48 PM
bayou man's Avatar
bayou man
I have a '05 6.0 And I think the turbo is bad. It makes a rubbing or grinding sound and there is no power when it acts up. If there is an updated 6.0, I must not have gotten one. I have an appt. with the dealer next week, I'll find out then.
Old Feb 3, 2006 | 10:39 PM
unclmike's Avatar
unclmike
Hey bayou man I did notice that fuel consumption was up when the problem started.My unit is sticking meaning ,when its freed up it will make boost.These variable geometry turbos are pretty tempermental.I just hope mine gets replaced with a GOOD unit.GOD BLESS US ALL.Ok maybe thats alittle overkill.Just want my truck back in one piece completly funtional and with no damage from steelership yano.
Old Feb 4, 2006 | 07:08 PM
bayou man's Avatar
bayou man
When mine acts up, I have almost no power and it barley moves. It also pours out black smoke. I don't think it is sticking, it must be off center, it sounds like it is rubbing on the housing. When it makes the noise it sounds like it's coming from the air cleaner. I can't think of anything else it could be? I hope they don't flash it at the dealer, maybe I should move computer hookup. I'm not looking forward to the dealer working on it, it is a van and the turbo will be a pain to change, I hope they don't have to pull the engine. On my last van they had to take the entire front end apart, the motor has to come out the front. I see from your profile that you are a contractor. If your business gets slow you can come to new orleans, there is enough work to keep you busy for years, especially electrical, you can can name your price and people will pay. There are a couple hundred thousand houses that need to be re-wired. Sorry for the long post, and thanks for the reply.
