Autometer Gauge Wiring
Old Apr 6, 2015 | 06:34 AM
seagiant's Avatar
seagiant
Hi,
Looking to hook up a water temp and volt guage to my 1989 F-150.
My question is the wiring for the backlighting. Was wondering where you guys are getting your power for the backlight and how (connection) you are getting it???
If I do not go to a dimmer circuit is there a way to set the brightness of the backlighting and leave it there?
Any info on the most painless way to do this is appreciated!
Old Apr 6, 2015 | 06:57 AM
MtTheJeffro's Avatar
MtTheJeffro
Tap into the dimmer switch for the dash lighting on the back of the headlight switch. This way you can dim the gauge lighting with your dash switch.
Old Apr 6, 2015 | 08:54 AM
Scndsin's Avatar
Scndsin
I pig-tailed off the hot wire to a bulb that lights up the A/C control panel. It was closest to where I hung my gauges.
seagiant's Avatar
seagiant
Hi,
Thanks! I hear that you have to tap into the (+) AND (-) wire or the dimmer for factory panel does not work?
Do you have any color info fo the wires I need or is it obvious???
Old Apr 6, 2015 | 09:51 AM
exranger06's Avatar
exranger06
If you have an aftermarket stereo, it's easy to tap into the harness there, and the wires are clearly labeled and color-coded. There's a switched +12V wire for gauge power, and an illumination/dimmer wire for the backlight.
Old Apr 6, 2015 | 10:10 AM
Scndsin's Avatar
Scndsin
Its been a while, but I believe in my case the A/C lighting harness used a black ground wire, rather than just chassis ground.
Old Apr 6, 2015 | 10:24 AM
dixie460's Avatar
dixie460
I'd just tap off the dimmer lead where the rest of the instrument lighting is connected. Not sure on the wire color for your year truck.
And please don't use a quickie connect blue thing or a butt connector either. Do it right by soldering the new wire to the existing wire. If you want to be able to disconnect it easily then get a single wire connector and solder that on first.
Ground you can pick up anywhere on the metal dash frame.
Old Apr 6, 2015 | 11:52 AM
seagiant's Avatar
seagiant
Hi,
Ok, I understand that I can go to the (12v+) dimmer wire and put in the pos. wire from the backlight wire from the Autometer guages, and then can really ground anywhere I want and my factory instriment lighting will still work???
Of course my power wire will come from a keyed source in the fuse panel!
Old Apr 6, 2015 | 05:33 PM
Fastback460's Avatar
Fastback460
For the lights on my gauges I just used an add-a-circuit and plugged it into the fuse slot for the instrument panel illumination.
That way it works with the factory dimmer, and I don't need to splice into any factory wiring.
Old Apr 6, 2015 | 06:33 PM
seagiant's Avatar
seagiant
Hi,
Thanks on my 89 I have instrument panel/clock dimming fuse # 10.
I guess that would work! Thanks!
Matt1966
19
May 20, 2017 08:55 AM
JZ_58F100
Jan 5, 2015 04:08 PM
deck60
Apr 6, 2012 09:40 PM
1-bigmac
Feb 2, 2008 12:03 PM
4x4turboterror
Apr 25, 2005 09:03 AM
