7.3l IDI injector brass washer
Old Apr 5, 2015 | 07:18 PM
1993idi's Avatar
1993idi
I have been having problem in the last couple days. My truck has been shaking on start up and smoking blue smoke. I found on my number 5 injector that the brass washer was blown out and I put a new one in and the same thing happen. Anyone know what's going on. I messed with it all day today and couldn't find anything. Thanks. Jack
Old Apr 5, 2015 | 08:18 PM
typefour's Avatar
typefour
That injector is junk.when the combustion gasses cook it the injector seizes, galls or whatever. It gets real unhappy
Old Apr 5, 2015 | 10:34 PM
1993idi's Avatar
1993idi
So do you think that is what is causing the shaking? And rough idle and smoke?
Old Apr 6, 2015 | 07:55 AM
typefour's Avatar
typefour
Very likely
Old Apr 6, 2015 | 09:20 AM
1993idi's Avatar
1993idi
So just get a new injector ?
Old Apr 6, 2015 | 12:26 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
it's best to replace them as a set.also note however,it's also best to replace the ip at the same time (especially if it's original) as well,because the injectors working correctly again,can strain an old tiered out ip.then of course,the timing should be set as well.
but if she's an old beater with a heater and you just want to keep helping it along,replace just that injector and see how she goes for a spell.
Old Apr 6, 2015 | 06:45 PM
typefour's Avatar
typefour
I do have some good used orphans around if you know your brand and code.
Old Apr 6, 2015 | 09:47 PM
1993idi's Avatar
1993idi
I actually just orders some new ones. Thanks though.
Old Apr 7, 2015 | 09:05 AM
typefour's Avatar
typefour
New or reman? from? some vendors are sketchy.
Old Apr 7, 2015 | 10:26 AM
1993idi's Avatar
1993idi
New Delphi injectors
dirt_biker
Oct 18, 2017 02:26 PM
zachbrown0413
17
Jul 4, 2016 01:47 AM
galute
May 5, 2013 07:35 AM
tobacco farmer
Apr 21, 2010 04:34 PM
fordpride
Mar 2, 2010 06:06 PM
