Blowing Blue smoke and rough running
Old Oct 17, 2017 | 10:32 PM
dirt_biker's Avatar
dirt_biker
When I’m cruising at 70mh very light smoke but going down hill I get a lot of smoke, when at idle I get a lot of smoke and if I run it up to 1200rpm it will cover any car next to me,
I had some one put a gage on it and it showed injector 2 was not working and he said the smoke is from the bad injector and it’s unburied diesel?
Any one know if a bad injector would do this?
PS. He thinks the injector lost the tip.
Old Oct 17, 2017 | 10:43 PM
FiznUKa's Avatar
FiznUKa
The first thing you need to do is not drive it until you figure it out. If it is a bad injector that lost its tip you risk burning a hole in your piston.
You need to run a bubble test immediately google its on YouTube.
Old Oct 17, 2017 | 10:59 PM
xcrsp440's Avatar
xcrsp440
What tests were run showing a bad injector?
Old Oct 18, 2017 | 05:30 AM
lanneinbc's Avatar
lanneinbc
That's exactly what mine did with a cracked injector tip. x2 on the not driving it!
Old Oct 18, 2017 | 10:44 AM
dirt_biker's Avatar
dirt_biker
I’ve already drove it back home (about 275mi, I hope it did not do more damage ),
I’ll pull the injector and see if the tip is still there.
Thank you
Old Oct 18, 2017 | 11:25 AM
lanneinbc's Avatar
lanneinbc
The tip was not missing in mine. You had to look very closely to see the crack, but it ran the whole length of the tip.
Old Oct 18, 2017 | 12:28 PM
dirt_biker's Avatar
dirt_biker
Glad to hear the tip of your injector was not gone I still have to do the bubble test I’m not sure what the bubble test shows or what does that prove one where the other I’m not sure what the bubble test supposed to do but I’m going to run it any, anybody wants to chime in on that it would be great thank you very much.
Old Oct 18, 2017 | 01:18 PM
lanneinbc's Avatar
lanneinbc
Search! FTE, and YouTube. Someone just posted a video here the other day.
Old Oct 18, 2017 | 02:26 PM
dirt_biker's Avatar
dirt_biker
Thank you I’ll check it out.
FL SuperDuty
Mar 13, 2019 09:44 PM
1993idi
Apr 7, 2015 10:26 AM
Dbailey
13
May 31, 2010 11:55 AM
sean23johnson
May 26, 2005 09:00 PM
