Piston differences?????
Old Sep 30, 2004 | 10:53 AM
AKBronc's Avatar
AKBronc
Question Piston differences?????
OK, I might be dumb here but what is the difference between dished pistons and flat top pistons? Im looking into getting a stroker kit and I came accross piston choices.
Old Sep 30, 2004 | 11:02 AM
poboy66's Avatar
poboy66
Flat tops are just that...(Flat) except for the valve relief notches cut in them.
Dished pistons usually have a semi-large circular depression in the top of them and this usually will lower compression ratio.
Old Sep 30, 2004 | 11:03 AM
Homespun91's Avatar
Homespun91
A flattop piston is, as you might guess, flat on the top. No dish, no dome. As a rule they do have valve reliefs. A dished piston has a concave "cut" out of the top, sort of like a very shallow dish with thick edges. A dished piston is normally used to lower compression.
The current thinking is to use a flattop or dished piston, combined with the appropriate size combustion chamber in the cylinder head, to get the compression ratio you want. The older method was to use a domed piston, which can inhibit flame travel.
This is all pretty general; it really depends on what parts you currently have, what engine, & what you want to do. If you have '70s heads, they usually have pretty big chambers & you may have to use a domed piston. With most stroker kits, you don't need to anyway. Hope it helps!
