compression versus deck height
Old May 11, 2007 | 12:52 AM
dogsniper's Avatar
dogsniper
What is the relation between say 10:1 cr pistons and .035 deck height and the same pistons with 0 deck height. What does the cr rise say for every .010 less deck height? In a 390
Old May 11, 2007 | 10:57 AM
rusty70f100's Avatar
rusty70f100
The amount depends on the other factors of the compressed volume, like gasket volume and head CC's.
Doing some calculations:
68cc heads
10cc dish pistons
4.4" .041" gaskets
.035" deck clearance
4.080" bore, 3.784" stroke
=9.47:1 compression
68cc heads
10cc dish pistons
4.4" .041" gaskets
0 deck clearance
=10.19:1 compression
Difference = .72
76cc heads
10cc dish pistons
4.4" .041" gaskets
=8.82:1 compression
76cc heads
10cc dish pistons
4.4" .041" gaskets
0" deck clearance
=9.43:1 compression
Difference = .061
So you see, it varies. A normally higher compression motor will gain more from that .035" than a lower compression motor.
bigdan1979f-250
May 11, 2009 05:05 PM
doug1222556
35
Jan 28, 2008 11:08 AM
scrapperdan
Feb 3, 2006 03:30 PM
EgoMan
Nov 27, 2004 04:27 PM
PigFarmer
Mar 20, 2002 01:17 PM
