stock compression?
Old Apr 4, 2015 | 09:30 PM
greentruck72's Avatar
greentruck72
stock compression?
what is the stock compression for a 68 truck 390?, and how much would it have been increased when I shaved my heads
Old Apr 4, 2015 | 10:55 PM
85e150's Avatar
85e150
Without looking it up, I want to say 8.2 or 8.4. They do this with a short piston from the 410. It sits .100 or so down the hole, so shaving the head isn't going to get you much except goofed up gasket sealing and custom push rods.
A compression calculator, millions of which are on line, can tell you the difference once you plug in the specs. You will have to try to figure out about what your new combustion chambers will be.
The 410 piston is a flat top with valve reliefs. You will have to do the math on exactly how far down the hole it is.
Old Apr 22, 2015 | 01:36 PM
greentruck72
guess i forgot to say that my engine is a 68 truck 390, but i have bored it.040 and the pistons sit flush with the deck, it has shaved heads as well(dunno how much though), pistons are dished for the valves
Old Apr 22, 2015 | 11:58 PM
85e150's Avatar
85e150
You asked for stock compression. You do not have a stock pickup motor.
You need to measure your combustion chambers. Also, do your pistons have a dish or just 4 cuts for the valves?
10.5 CR pistons were flat top with the valve cuts.
9.5 CR pistons had a small dish with the valve cuts.
Sounds like you used car pistons in your rebuild. Pickup spec pistons would be .100+ down the hole.
Compression calculators:
http://www.summitracing.com/expertad...ion-calculator
https://www.rbracing-rsr.com/compstaticcalc.html
Old Apr 27, 2015 | 08:19 PM
greentruck72
yeah I know but I figured I could fill the rest in thanks
Old May 4, 2015 | 11:36 AM
orich's Avatar
orich
Cutting/shaving/milling and you don't know how much. Now you'll have to possibly have your intake manifold shaved also for proper intake gasket sealing. If not it won't be long you'll be pulling the intake replacing the gaskets.
set your intake on the engine of bolted down heads and Check intake gasket gap clearance. If heads have been shaved more then .020 then intake should be milled to correct square ness fit of gasket.
Orich
Old May 4, 2015 | 04:02 PM
69cj's Avatar
69cj
Orich
Your also looking at possibly diff. push rods. Those numbers are imp. to know.
NW 150
18
Sep 4, 2012 07:00 PM
dogsniper
May 11, 2007 10:57 AM
AKBronc
Sep 30, 2004 11:03 AM
gktbay
Aug 19, 2003 06:00 AM
bigeric
Mar 14, 2002 08:56 PM
