New distributor ?
Old Apr 3, 2015 | 08:01 PM
BKM-WR3's Avatar
BKM-WR3
New distributor ?
It's time for a new distributor in my 1987 302. I am told the pick up coil in the distributor is causing my problems. So far I have replaced spark plugs and wires, Ignition control module, Coil, fuel filter, distributor cap and rotor button. All Motorcraft parts.
I am still having the same issue. The truck cuts off like somebody hitting a switch. Most of the time it comes right back as fast as it cuts out. Every once in a while it will cut off completely. It has always started right back less than a minute.
My main question is what distributor do you guys recommend? I was looking at the CARDONE SELECT from rock auto. Is this a quality part.
Old Apr 3, 2015 | 10:10 PM
wtroger's Avatar
wtroger
I have used them without issue.
Old Apr 3, 2015 | 10:25 PM
BKM-WR3's Avatar
BKM-WR3
wtroger Thanks for your reply.
Old Apr 4, 2015 | 10:16 AM
'89F2urd's Avatar
'89F2urd
about 2 years ago, when I finished my 351, I ran a cardone from rock auto for about 2 months before the PIP went bad in the dizzy. I went to the jy and got a motorcraft that ive been running ever since. if you get the cardone, leave a spare dizzy in the truck.
Old Apr 4, 2015 | 10:47 AM
PlumCrazy7's Avatar
PlumCrazy7
It's pretty easy to just rebuild one, I got a motorcraft TFI module with 2 year warranty and a BWD pick-up with a lifetime warranty for about $117. So for the price of a cardone you can have a good, warrantied distributor to not worry about. All you need is a puller, hammer, and a set of deep sockets to drive the gear on.
Old Apr 4, 2015 | 11:22 AM
OldGrayFord's Avatar
OldGrayFord
I saw the warnings about the rebuilt models, but I was in a time crunch and the store had a card one in stock. I've had it a couple years no issues
Old Apr 4, 2015 | 01:25 PM
rla2005's Avatar
rla2005
We frequently have posts in this forum from folks using a "rebuilt" distributor. Anyone getting more than a few months of operation out of it should consider themselves very lucky. Go buy a lottery ticket...now! Before the luck runs out.
Old Apr 5, 2015 | 08:25 AM
BKM-WR3's Avatar
BKM-WR3
Thanks for all the responses. It sounds like it's a real crapshoot buying a rebuilt distributor. I do not have the tools or the know how to rebuild mine but I'm always willing to learn.
Does anyone know of a write up or a video showing how to rebuild a distributor?
I guess I could consider doing the junkyard thing but I guess that's a gamble too. Can someone tell me what years distributor will fit in my 87?
Thanks again for the help.
Old Apr 5, 2015 | 09:04 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
The pickup fails and the bushings wear. That's pretty much it for rebuilding a distributer. Disassembly and reassembly are not difficult. Check your bushings for side to side play and if they are good, put in a new pickup and put it back in the truck. Worn bushings means some machining to replace, or get a better core from the junkyard. They are not hard to find. If you can't find one, a remanufactured distributor is always an option.
Checking bushings is a simple wiggle test. If there is play, you will feel it. No disassembly other than taking the distributor out of the engine. There are two bushings, top and bottom. Wiggle the rotor shaft side to side same for the gear end. There will be some up and down play, but you should not feel any side to side play.
Old Apr 5, 2015 | 09:19 AM
rla2005's Avatar
rla2005
From my buddy Joel 5.0: TFI
Old Apr 5, 2015 | 04:06 PM
BKM-WR3's Avatar
BKM-WR3
Thanks rla2005.
That's a good write up! If I decide to rebuild mine that will be very helpful.
Tyler Burns
Jun 24, 2020 06:57 PM
TGH
1978 - 1996 Big Bronco
Jul 27, 2016 11:43 PM
66 sandrail
1983 - 2012 Ranger & B-Series
Sep 9, 2012 08:22 PM
carlyoung
May 19, 2012 12:56 PM
ddsvi
64
Apr 29, 2011 10:17 PM
