93 Distributor Pickup Module
Old Sep 8, 2012 | 11:02 AM
66 sandrail's Avatar
66 sandrail
I have a 93 Ranger with a 3.0 V6 and electronic distributor with no spark out to the plugs. The coil fires when you turn the engine over with the wire pulled out of the dis. cap, but no spark to the plugs.
I removed the dis. and carried it to the local Auto Zone, and O'Rileys to have the pick-up module tested, and both stores say they cannot check this particular module.
Can someone please tell me where I may be able to have it checked? Does a ford dealership have the equipment to check it with the dis. out of the engine??
Thanks Leland
Old Sep 8, 2012 | 04:31 PM
critterf1's Avatar
critterf1
If it's firing like that the dizzy is doing it's job. I'd be looking at the cap and rotor. The pick up module tells the coil when to fire.
Old Sep 8, 2012 | 06:17 PM
66 sandrail
Thanks critterf1.......I will check the cap and rotor. I did notice that the steel piece that bolts on plate under the rotor has different width tangs on it, seems they would all be the same width being as they determine when the coil fires.
Do you understand what I am talking about here??
Leland
Old Sep 9, 2012 | 07:40 AM
pawpaw's Avatar
pawpaw
I agree, if you have a good blue hot spark out of the coil, through the coil wire To the distributor cap, but not to the plugs, then the rotor, distributor cap & plug wires should be on your suspect list.
If the rotor insulation is breaking down to the distributor shaft, it'll short out, or weaken the spark voltage to the plugs.
Old Sep 9, 2012 | 08:22 PM
66 sandrail
Thanks guys....as always Yaw have come to the rescue !!!
Leland
gysgtbigdaddy
Aug 19, 2013 11:14 PM
sailorjohn
Bronco II
Jul 20, 2007 09:36 AM
4xFordFreak
May 13, 2007 09:43 PM
irishguyincc
18
Apr 7, 2006 06:02 AM
Coondawg
Dec 7, 2003 02:37 PM
