stumped....
Old Apr 3, 2015 | 07:23 PM
fordboy300's Avatar
fordboy300
stumped....
So today I drove the truck today finally give the C series a road and wouldn't you know it. The symptoms of a bad coil maybe a faulty ign. module came back to haunt my truck. I've just about had it. I thinks it's time to upgrade the ignition I want to get a DUI as much as the next guy but right now that's out of the picture for me right now. I've been reading up on the Mallory Hyfire 6AL looks to be a nice upgrade. Any thoughts?
Old Apr 3, 2015 | 08:22 PM
The Frenchtown Flyer's Avatar
Originally Posted by fordboy300
Any thoughts?
CHEVY HEI conversion. Under 20 bucks.
Old Apr 4, 2015 | 10:02 AM
Harte3's Avatar
Harte3
What FTF said X2.
Old Apr 4, 2015 | 10:27 PM
Biblethumpncop's Avatar
Biblethumpncop
I agree with the HEI. Make sure you get a quality module from NAPA. The first one I got from Autozone was junk. My NAPA part is still going strong.
Old Apr 4, 2015 | 11:18 PM
fordboy300's Avatar
fordboy300
What's the advantages driveability/performance wise? I have read that's it's just like the duraspark 2 module? I'm not to convinced.
Old Apr 5, 2015 | 01:45 AM
F-250 restorer's Avatar
F-250 restorer
I tried the gm module. It is cheap and easy to install. It was, however, a noticeable drop in performance from my msd box.
I would use the Mallory box. That will allow you to use their 60,000 volt coil too. But for that you need good wires. You will still need the DS2 module to trigger it. I recently changed mine. Get the oem motocraft one NOS on ebay. The high quality cheap Chinese C... elsewhere will last a couple of years. Make sure your dizzy shaft has zero play. Don't buy the Cardone rebuilds, I mean Cardone washing service.
You will be Very happy with performance using the Mallory.
If you want a stock feel, go with the GM 4 pin.
Old Apr 5, 2015 | 10:07 AM
roadrash63's Avatar
roadrash63
Talking
With hei you can leave the key on and not !
Burn up the module !
Old Apr 5, 2015 | 10:45 AM
fordboy300's Avatar
fordboy300
Finally yes that's the answer I was looking for. How exactly did you hook up your MSD box. I thought the ign box would eliminate the ds2 module? I found out the other day that MSD bought out Mallory.
BTW Happy Easter!
Old Apr 5, 2015 | 12:01 PM
F-250 restorer
Even with the GM 4 pin you have to use the DS2 module to trigger the system.
Here is a link for the 4 pin: TRICKY or TRICK? HEI Module Inside Duraspark Case - Ford Muscle Forums : Ford Muscle Cars Tech Forum
The MSD comes with book showing you how to wire it. Here is the diagram I use.
The ground is crucial. I grounded right to the frame. They don't like heat.
On a side note: I have heard nothing but good things about Mallory. I have used the msd for five years w/o issue. The only thing is that the cap and rotor are not optimal for so much juice and fowl after 6 months. So... I bought the borg warner from O'reiley's with a life time warranty and change them twice a year for free. Just use the contact grease when installing and it takes 5 minutes.
Spoonman75
30
Oct 10, 2015 04:56 PM
MikeGV
Electrical Systems/Wiring
Jan 8, 2005 09:37 PM
dvldog458
Jul 4, 2004 02:26 PM
ScottInTexas
Apr 15, 2004 07:48 AM
DFB2004
Jul 15, 2002 12:19 AM
