Ignition Module Bad?
Old Apr 13, 2004 | 06:43 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
Since my truck just failed me and is sitting on the side of the road waiting for the sunrise, I thought I'd ask about my ignition module. If you can get to my gallery there are some photos. One of them is of the ignition module. In the top center of the photo you can see some kind of black goo running down the wheel well from the ignition module. What the heck is that? I think it may be the guts of the module that got real hot and melted. Truck still starts and runs (most of the time) but it runs rough, then perfect then rough again. You never can really know when it will be perfect.
I don't know whether I have the Duraspark 2 or 3 either. Does that make a difference and would you replace it with the same or another after market brand?
The problem this morning will most likely be the float is stuck in the carb (I hope). Just got to tap it a little. Maybe the fuel inlet baffle is binding the float.
Thanks for the input.
Old Apr 13, 2004 | 10:43 AM
84-250's Avatar
84-250
the duraspark 2 dizzy has a vac canister mounted on it while the DS3 does not. do you have a square coil or a round one? round coil for the duraspark ignition and the square coil for the TFI ignition which has a rectangle module mounted to the dizzy.
Old Apr 14, 2004 | 08:10 PM
ScottInTexas
Round. I found out that the duraspark 2 is in my truck, the three is reserved for trucks with an ECC.
I still find the black goo kinda scary. You think it's guts are leaking out?
Old Apr 15, 2004 | 12:33 AM
200000+F150's Avatar
200000+F150
Yep! I've never torn into one of these, but have enough electronics background to tell you if it's got goo leaking out it's either history or
REAL close. Don't know if it's what caused your truck to quit, but very
likely, and if it's melted down I'd swap it anyway, or you'll be walking a second time very soon.
Old Apr 15, 2004 | 12:47 AM
Fordtech1's Avatar
Fordtech1
Put the goo back in...oozing modules are a bad thing! Seriously, the "goo" is there to stabilize and support the electronics inside. Leaking or oozing denotes an overheat condition within the module, and steer clear of the cheap aftermarket junk units. Make sure the wiring is in good shape going to the stator (pickup inside distributor), shorts there or inside wher the advance plate moves them is also bad for module voltages.
Old Apr 15, 2004 | 06:27 AM
ScottInTexas
Yep, I'll be hunting down a module today. Hopefully I can get by until Saturday and can do the job then. Nice thing about it is the location of the module. Should be able to change it out in a few minutes.
BTW, was anyone able to get to my pics in my gallery? I'm not sure if they are accessable to everyone.
Old Apr 15, 2004 | 07:41 AM
Stanstruck's Avatar
Stanstruck
Let us know how your module project works out.
No, I couldn't see any pictures in your gallery.
Stan
Old Apr 15, 2004 | 07:48 AM
ScottInTexas
Thanks for the reply. I need to find out how to use the gallery.
tchopper1969
Mar 22, 2011 08:36 PM
64fordf100292
Dec 9, 2009 10:19 AM
rainbowATF
Aug 25, 2009 05:50 AM
danhandled
New Member Introductions
Feb 23, 2009 12:47 AM
firefytr29wfd
1997 - 2003 F150
Jun 23, 2005 12:29 AM
