Issues with my Carb
Old Apr 1, 2015 | 04:10 PM
mr78F150's Avatar
mr78F150
Issues with my Carb
I finally got the truck running but when i close the choke plate it dies out, when I press on the gas it dies out. All it wants to do is die, all I want it to do is live. I have rebuilt the carb, placed a new fuel filter, now I dont know what to do.
Holley 1850 4 barrel
Inline fuel filter
Thanks for the help
Old Apr 1, 2015 | 04:21 PM
gatorfor88's Avatar
gatorfor88
If you close the choke plate it should die out.
Old Apr 1, 2015 | 04:33 PM
mr78F150's Avatar
mr78F150
why? it should just idle. the choke plate shouldnt stay open the entire time you drive
Old Apr 1, 2015 | 04:43 PM
gatorfor88's Avatar
gatorfor88
That is what a choke does. Its why they call it a "choke".When its open it lets air in, when its closed it "chokes" the engine.
Old Apr 1, 2015 | 04:44 PM
mr78F150's Avatar
mr78F150
so why would the truck bog out when i press on the throttle?
Old Apr 1, 2015 | 04:50 PM
TheMonson's Avatar
TheMonson
......april fools?
If not, it dies because it isn't getting enough air when the choke is closed. And yes it should stay open once the engine is warmed up.
Old Apr 1, 2015 | 04:52 PM
mr78F150's Avatar
mr78F150
Okay see now you guys have my mind blown. because holley says to close it after the truck is at running idle. so why should it stay open the whole time?
Old Apr 1, 2015 | 04:59 PM
TheMonson's Avatar
TheMonson
Not quite sure where you may have read that. Just to add to your confusion, some guys eliminate the choke all together.
I attached the bit about adjusting the choke. Here is the full manual straight from holley.com - http://documents.holley.com/199r7948-5rev6.pdf
Old Apr 1, 2015 | 05:04 PM
mr78F150's Avatar
mr78F150
I have a manual choke not an electric. but if leaving it open then adjusting everything is best then i guess that what i need to do.
Old Apr 1, 2015 | 05:18 PM
TheMonson's Avatar
TheMonson
Engine needs 4 things to run; air, fuel, compression, ignition (spark). When you close the choke, you're restricting the amount of air the engine can take in. It helps get things started, but isn't intended or designed to be operated (or closed) full-time.
This article may help clarify your understanding - http://en.wikipedia.org/wiki/Choke_valve
Old Apr 1, 2015 | 06:09 PM
mr78F150's Avatar
mr78F150
okay so I will probably just remove the plate. but lets get to the point where when I pull the throttle open it will "choke" and shut off. any ideas on that?
Old Apr 1, 2015 | 06:23 PM
Tedster9's Avatar
Tedster9
How old is the carb? They need cleaning or "rebuilding" every few years, especially if they have sat for a long time. Make sure linkage isn't binding, idle mixture adjusted, idle RPM etc. Shouldn't have to remove the choke plate.
kennyfzj80
Oct 12, 2015 10:16 PM
fantomas
Feb 18, 2009 12:23 AM
gearhed1971
Apr 8, 2007 08:10 AM
antunez13
Nov 29, 2006 11:04 AM
gearshift101
Nov 29, 2004 08:22 AM
