knocking after oil change
Old Mar 31, 2015 | 08:49 PM
cherrybomb37's Avatar
cherrybomb37
Hi guys, long time user, first time poster in the 6 section. I have a 1990 F150 I changed the oil from my winter 10w-30 to summer time 10w-40 and now when ever I start the truck it has no oil pressure for 3-5 seconds, red CEL comes on, gauges is at zero and it sounds like a power stroke then it planes out and runs perfect. It does have 312K ( most miles I've ever had on a 6 ) my past 300 I have run the same oil, same filter and never had an issue. Any idea how I could resolve this? I am currently rebuilding another 300 to throw in the truck but I would like this engine to last at least another 6-12 months. Any ideas??
Old Apr 1, 2015 | 10:39 AM
AbandonedBronco's Avatar
AbandonedBronco
Hi cherrybomb,
What oil filter did you use? Some oil filters don't have a good drain-back valve to keep oil up in the engine, so when you start it up the next morning, it's dry. I had this problem when I used Fram oil filters. When I switched to a Motorcraft, the problem went away.
Old Apr 1, 2015 | 11:07 PM
cherrybomb37
Took the advice, bought a motorcraft filter swapped out the fram, now she has oil pressure on every start. I have always ran fram PH8A filters on my 6's without issues but now I will be running the motorcraft.
Old Apr 2, 2015 | 09:13 AM
1986F150six's Avatar
1986F150six
It is hard to beat OEM! The FL1A filter can be bought at Walmart for less than $5.
Old Apr 2, 2015 | 09:33 AM
AbandonedBronco
Glad to hear the simple fixes still work from time to time.
Old Apr 2, 2015 | 09:49 AM
timbersteel's Avatar
timbersteel
Awesome to see it was a simple fix.
FWIW, I wouldn't touch a Fram oil filter with a 10 foot pole.
Google "Orange Can of Death" for more Catastrophic engine failures due to Fram.
Old Apr 2, 2015 | 10:28 AM
Parsedout's Avatar
Parsedout
My Walmart was out of the motorcraft filters when I stopped by so I picked up a Purolator. I've always had good luck with those as a second best to OEM. It's amazing that Fram is still in business, stuff is junk.
h8jfgrdn
Jan 20, 2014 05:17 PM
breisr
Oct 9, 2009 02:35 PM
diesel_hillbilly
Jun 26, 2009 09:46 PM
goodwrench
Sep 26, 2005 05:56 AM
xericx
Nov 24, 2003 01:23 AM
