Sponsored by: Auxito
transmission leak
Old Mar 31, 2015 | 07:43 PM
yunue90's Avatar
yunue90
transmission leak
Hi I have a 97 ford f150 v6 2wheel drive. I was driving to work when l heard rattling in the engine like something came loose when I stopped to check my transmission fluid was pouring out drained out in 2mins tops. Can someone help and let me know what you think it could be?
Old Apr 1, 2015 | 10:33 AM
rmccbride's Avatar
rmccbride
might just be a rusted cooling line. Where was it leaking from, under the engine or the trans?
Old Apr 1, 2015 | 11:59 AM
yunue90's Avatar
yunue90
It was leaking from the engine.
Old Apr 1, 2015 | 12:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
So something broke inside the engine. That won't leak transmission fluid.
Old Apr 1, 2015 | 12:29 PM
rmccbride's Avatar
rmccbride
What color was the oil that was leaking out?
Old Apr 2, 2015 | 07:59 AM
yunue90's Avatar
yunue90
It was definitely transmission fluid. Didn't mean it was coming from the engine but under the engine. The liquid was red color.
Old Apr 2, 2015 | 08:22 AM
rmccbride's Avatar
rmccbride
Then it's got to be the trans cooler lines that run to the radiator. Then tend to rust through. Easiest fix is to cut out the part that is leaking and splice in a rubber hose.
But the question is going to be what was the noise you heard and how much damage was done if you were running low of trans fluid.
hharris8
Aug 11, 2016 10:04 PM
Dirt-Road-Kid97
Oil & Lubrication
Jan 20, 2014 01:00 AM
aaron11b
Mar 15, 2011 06:46 PM
ustolemycupcake
Mar 3, 2005 07:31 AM
