Sponsored by: Auxito
Fuse box or Gem module?
Old Mar 29, 2015 | 05:21 PM
roddog101's Avatar
roddog101
Hello all,
I have a 98 f250 ld 4x4 xlt 3 door 4.6l with approx 134000 miles on it.
I don't have a leak in my front wind shield.
So my question is.
When I start the truck sometimes the gauges will go all the way down like if the truck is off. If I play with the fuses they will go back up and it will run great. Some times the engine will surge...again play with the fuses then it will run great.If I don't get to the fuses fast enough it will die when it is surging.
Also on one of the fuses I can hear a noise like it is shorting out sometimes.
So I don't know if I need to change out the fuse box or look for a bad ground?If I need to look for a bad ground I have no clue where to start.
Please help before I spend money that didn't need to be spent.
I miss my truck.
hope I gave you all enough info if not please let me know. Thanks in advance
Old Mar 29, 2015 | 08:55 PM
Bluegrass 7's Avatar
Bluegrass 7
Repair for the power issue.
The GEM has little to nothing to do with the dash display or power to the computer.
Good luck.
Old Mar 29, 2015 | 10:13 PM
roddog101's Avatar
roddog101
Thanks for the info
rigbyrigz
Electrical Systems/Wiring
53
Feb 23, 2020 07:41 AM
Bunny9000
Apr 14, 2015 02:48 PM
BubbaG7216
Jun 27, 2014 05:42 AM
hedhntr
Jan 21, 2007 07:01 PM
germanbrave
Sep 15, 2005 12:25 PM
