Which Fuse Box substitute can go on F250
My cousin has figured out with grounding and testers and lots of hours and tries that I need a new fuse box to replace 3C3T-14A067-AP on 2002 F250 SD SuperCab 4D XLT auto 7.3L diesel 1FTNX21F32ED54794
Its an under dash. I cannot find an exact match anywhere. I can find xCTC-14A067-yy where x is 7 or Y or something other than 3 for first digit, and
yy is ED or BG or something other than AP.
The Fits your vehicle lookups and attempts to find what part of the fuse box part number means year, or 7.3, or under hood/dash and other sources of compatibility have failed me.
2002 F250 sitting dead no power. Can anyone please either reliably suggest if 7YCT-14A067-AP or 3CTC-14A067-ED or other variation will be OK to use to replace my dormant 3CTC-14A067-AP, or at least fix me up to a chart explaining what digit means what? FUSE BOX THANK YOU!
Last edited by rigbyrigz; 04-10-2017 at 06:32 PM. Reason: corrected 14067 to 14A067 also corrected vin last2 from 84 to 94
THANKS! Cousin technician says fuel pump relay - non-serviceable in the fuse box - not coming on, no power. Seems might be a common problem this model from a water leak (shorted out) - don't have any signs of a leak, but a very vigorous power washer and degreaser effort might have fried it somehow. IDK.
Seems like there are under hood version of fuse box and under dash as well (which this is) I suspect not interchangeable so worried a bit about maybe $200 to try something used that "might fit". I also heard "most of the stuff in that series and year" is interchangeable, but also cousin said something new in 2002 might make it not so likely. Hence trying to get as close a part as I can (to 3CTC-14067-AP, very few even near-matches) or some assurances from you kind folks! - Thanks!
Might be of general interest. Computer and all seem fine, he can get wait for starter, turn-over with ether or some other trick, just fuel pump (which checked out) won't get power. Found complete (green w/ yellow) circuits and wiring and inertia box and all suggesting its def the fuse box not behaving properly. Its obvio I'm a duffer he's the tech. Thanks! Peace!
...oh, and the under hood fuse box GEMS cannot be swapped with an under dash one, so getting this right (as possible) seemed important
We have had some posts on here where the embedded trailer tow running lights relay has also burnt out. With a little re-wiring and another relay wired outside the box, it can be a work around. Some people have even printed out this procedure and taken it to the dealer and they have said it will work, don't know if they convinced them to do it or not.
First thing I would do is make double sure he is on the right track. He may have done this and I missed it, but I would run a hot wire to the darkgreen/yellow that feeds the inertia switch temporarily and see if the truck will run. Look at page six in this link.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=29302
If that works, then I would take a meter and measure the voltage on the lightblue/orange leaving the fuse box, going to the computer. When the engine is cranked, this wire should ground out and make the relay inside the fuse box click on. If it does not ground out, then the computer may be the problem. You can ground this wire manually and if the fuel pumps run and the truck runs, the computer is the problem.
If the computer is not the problem, what I would do is go to the store and get a Bosch type relay you use for foglamps(around 30 amp relay would do). Also buy 2 fuse taps.
First look at page 6. You will see power for the relay comes from "D". D is located on page 3. Go up to page 3, you need to plug in a fuse tap into fuse 22. This only has power when the ECM relay comes on. Run a wire from the fuse tap at 22 down to the new Bosch relay coil.
Go back to page 6. Plug in another fuse tap into fuse 40. Run a decent sized wire, at least 14 gauge from this fuse tap to one of the contacts of the Bosch relay.
On page 6, find the lightblue/orange that leaves the fuse box and goes to the computer, and cut this wire or just splice into it if you don't want to cut it, and run this to the other side of the coil on the Bosch relay.
On page 6, find the darkgreen/yellow leaving the fuse box feeding the inertia switch, and run this to the other side of the contacts on the Bosch relay. You could also just run a 14 gauge wire from the bosch relay and tie it to the inertia switch.
So you have a new relay piggy backed onto the original circuits to do the job on the internal relay. Like I said, we have done this before with the trailer tow running light relay and it works fine.
Once again, thanks so much Dave! I have passed all the excellent material and suggestions on to cousin...
...I think he did all (or most) of that already, but good to make sure. I was there (helping trace the darkgreen-yellow wire and all,) but not all the times he worked on it.
He has a nestegg of relays and fuses he toyed with. I know he did the hot wire splice and all, ruling out the computer in the process. He had the fuse box diagram on phone screen as a guide all the time, etc. His exact words were he " ran a straight to the fuel pump to make it come on but it still wouldn't come on".
The piggyback idea may be new, and perhaps a Godsend. So we really are appreciative of your interest and effort. We also have a friend at the Ford dealership that might do (an Oasis? Ford?) parts lookup tomorrow for compatibility issues (for 3CTC-14067-AP) in case we end up with that route left. THANKS!
Hi SHO89. THANK YOU! Lotsa sellers claim otherwise of course on Bay and such (selling an 01 as "FITTING 99-03" and such).
(For 3CT3-14067-AP) But I'm focusing on 2002+ parts now. Seeing some 2005 yanked 5C3T-14067-AE under dash ones for example listed...
Wondering how I should evaluate what it came from (if not exact match of course). Is 2005 an OK match for 2002? Does the unit have to come from a 7.3 since I have 7.3, or can 6.4L work,etc? As I try to get "closer" the more I can learn from experts what supposedly will or won't match is very helpful! (And what part of the PART.NO. means what). Thanks!
Seeing a 3CTC-14A067-EC on a 2003 SD; says FITS 2003-4. Doesn't say 7.3 or under-dash or anything. - and I see pic, it does have the A in 14067. And I think I have been making a typo here, its 14a067 I think. Losing my mind, sorry. Gotta go double-check... F250 is up the road an hour away.
closest so far is: Ford F250 F350 7.3 Diesel Fuse Panel Box 1C3T-14A067-AC
with a May 2001 date on the part.
Might be OK for my 2002 4wd-4 xlt F250 SD 7.3 under-dash, or not. seems my CORRECT part nbr is 3C3T-14A067-AP
Most who list a part from 99-01 are good enough to say "fits 99-01". some says fits 99-03 and are probably misinformed. All of course tend to say check your part nbr carefully to confirm fit. LOL.
in case anyone else gets here on a similar search, here is our forums posted answer to legend of digits, fyi:
To explain prefixes and suffixes...
Prefix:
1st digit: year (2 would be 2002)
2nd & 3rd digits: vehicle code (C3 is Super Duty, not sure what C7 is)
4th digit is the design responsibility code (which department was responsible for designing this part)
Suffix:
Shows revisions and tweaks to the part. For instance, AA would be the first design, AB would be the first revision, AC, AD, etc. When the first letter changes, it indicates a part that has the same function, but is different. It would revision the same: BA, BB, BC, etc.
Where you have to be careful (especially with electrical) is with the suffix's. "something-AA" and "something-BA" might both be, say, an under-hood fuse box. They both do the same basic function. But "something-AA" might be from a SD truck, where "something-BA" might be from an Excursion. Everything in the part number could be the same except the first letter in the suffix and you have two different non-interchangeable parts.
With electric, you often have to be careful with the year as well. Lots of things change from year-to-year.
With YOUR fuse panel, with the suffix of -AN, that's 13 revisions past the base part. A revision can be an upgrade, a fix, or just a different version for specific options. Revision changes on electric items can be pretty vague.
I can tell you this though- the 1C7T-14A067-AA is NOT going to work without modifications- lots of electrical changed between 2001 and 2002. I'm pretty sure the 6C3T-14A067-AB is a no-go as well, being a 2006 part.
The 2C7T-14A067-AP is the same year as what you have, and it is only 2 revisions past yours. All you need to figure out is what those revisions are...
Prefix:
Suffix:
