bought my mom a 66 ford like she had when she was 12.. planning to retro/rebuild it by her b-day 2016..
piced this up locally almost rust free and only a hand full of pop nots..
long bed fleetside 2wd, fe, 4spd in white with dealer ac in custom cab trim...
need some vin door tag help..
vin f25yk776873
door tag 129 M f250 D81 A B4 7500gvw 172hp@4000 options code 62
the truck has a fe in it (stroke to be measured later today) block #s small k and a large V up behind the oil filter adapter.. heads on this block reads c6te-c
bought a 360 from the boneyard as a back up.. has block tag and rebuild tag.. (stroke to be measured also).. block number a small 1e24 and a large W up behind the oil filter adapter.. heads are c7ae-a
plans are to swap in a 75-79 dics brake and power steering front end, and rebuild a fe (probly the 360) w/offy intake, edelbrock carb, headers, rv cam, diaghram clutch, and some chrome.. repaint moms pacific blue and white and replace some missing chrome.. fix dealer ac, 16" wheels w/trim rings and hub caps.. bronco rear bumper, dual 2 1/2" exhaust and replace the grill. (if I can find a nice one)
I have a show polished 66 grille (polished by Robert, a member here). with the polished headlight trim as well.
I bought the grille and then ended up buying a polished 65 grille from Robert. So now I have a 66 available. Better than reproduction since this is an original polished grille.
I want $600, plus shipping. That is a steal. Let me know if you need pictures, etc. It looks amazing.
Rich
Bought my mom a 66 ford like she had when she was 12, planning to retro/rebuild it by her b-day 2016. Picked this up locally almost rust free and only a hand full of pop nots. Long bed Styleside 2wd, fe, 4 spd in white with dealer ac in custom cab trim.
VIN: F25YK776873 / WB: 129 / COLOR: M / MODEL: F250 / BODY: D81 / TRANS: A / AXLE: B4 / MAX GVW LBS: 7500 / CERT NET HP: 172 / RPM: 4000 / DSO: 62
Styleside = Ford, a Fleetside is a Chevrolet. / DSO does not refer to an optionscode.
F25 = F250 2WD
Y = 352 2V
K = Kansas City MO Assembly Plant.
776873 = 1966, assembled November 1965.
129" Wheelbase.
M = Wimbledon White.
F250 2WD, 7,500 lbs. GVWR
D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
thanks for the info fellas.. especially number dummy. I was hoping you'd. help out with the vin.. apologizes about the fleetside/styleside slip.. I own and love fords but am stuck working on all makes and models to fund my projects.. some times the vocabulary bleeds into other conversations.. but I bleed blue oval.. will keep the grill info in my note book but currently is out of budget till the truck progresses.. looks like the 71 360 will be rebuilt for the install cause the 352 has internal damage. hoping for the 2 piston front end and the older p.s. setups.. was aware of the diffrences as I own and work on 70s fords quite regularly, but appreciate the reminder.
UPDATE UPDATE...... looks like the 360 isn't a 360 after all.. its a 428 with 390gt heads....holy c*&p batman.. is this something I should keep for myself or should I stick it in the truck with that np435 behind it.... it has the block reinforcement ribs and the external harmonic balancer/weighted flywheel setup.. I pulled one head and intake to measure bore.. its on spec for a .30 over 428 (4.159).. and stroke checks too (4").. did I just find a holly grail or is this just a common toss off.. I've only owned 2 fe motors before this and both were true 390s. I know the 428 was fazed out in early 71 and my block #s come back as a 71 with 67 heads. so is this a reworked 390 or a left over gotta get it gone ford factory reject. and to make it more entertaining, what kinda smuck puts a 360 2v intake and headers on this kinda motor.. while im ranting what kinda compression/horse power would this engine make with a proper intake/cam/carb setup.. maybe even dual quads.. sorry long winded I get excited.. plus I bought it as a $100 core.
