Vin decode help please
Old Jul 23, 2013 | 03:59 PM
F&M's Avatar
F&M
I can get some but not all!
F11YK818757
F11=F100
Y=352 8CYL
K=KANSAS CITY
818757=FEB 66
129 G F110 D81 A 08
129 WHEELBASE
G=CHROME YELLOW
A=NP 4SPD
D81=LIGHT BEIGE WOVEN?
AXLE=?
05600 172 4000 441946
05600=GVR
4000=GROSS WEIGHT
DSO 441946=?
Help please.I'd aslo like to know front and rear axles.I see only one code.Thanks
Old Jul 23, 2013 | 04:00 PM
F&M's Avatar
F&M
PS I think this truck may have been a railroad or forestry truck
Old Jul 23, 2013 | 04:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by F&M
VIN: F11YK818757 // W. B. 129 / COLOR: G / MODEL: F110 / BODY: D81 / TRANS: A / AXLE: 08*/ MAX GVWR LBS: 05600 / CERT NET HP: 172 / RPM: 4000 / DSO: 441946
Several things you 'got' were wrong or incomplete, so here's the correct info.
F11 = F100 4WD
Y = 352 2V
K = Kansas City MO Assembly Plant.
818757 = 1966, assembled February 1966.
129" Wheelbase.
G = Chrome Yellow.
F110 = F100 4WD, 5,600 lbs. GVWR
D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
A = New Process 435 4 Speed Manual Transmission.
08* = Ford 9" Rear Axle / 3.50-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,600 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
441946:
44 = Twin Cities MN Ford District Sales Office, where the original selling dealer ordered the truck from.
1946: Domestic Special Order number, truck special ordered by original purchaser, not "bought off the lot."
* If the AXLE code contains a 3rd digit, it could decode to the 4WD's front driving axle type/ratio/capacity.
But after circa 1964, very few AXLE codes have a 3rd digit pertaining to 4WD
Old Jul 23, 2013 | 04:24 PM
F&M's Avatar
F&M
Thanks for all the help ND.Is there a reason there is no front axle code stamped here?
Old Jul 23, 2013 | 04:34 PM
NumberDummy
See what * refers to in post 3.
The front ratio will be very close to the rear ratio of 3.50.
Front driving axle has an ID tag which is located under one of the bolts that retains the inspection cover to the housing. Have you looked to see if it's still there?
Don't be surprised if it's missing. When people R&R'd the inspection covers, many forgot or didn't bother to re-install the ID tags.
Old Jul 23, 2013 | 04:38 PM
F&M's Avatar
F&M
got it ...thanks again!
3Bushwackers
Apr 29, 2020 04:52 PM
cmo
Large Truck
Aug 20, 2016 11:26 PM
MattEturbo
Large Truck
Aug 11, 2016 02:28 PM
IntrstlarOvrdrve
Dec 11, 2014 05:12 PM
CajunChris
18
Jan 15, 2014 07:55 PM
